gas mileage? - Page 6 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #51 of 60 (permalink) Old 06-29-2008, 04:15 AM
Daytripper's Avatar
just did a check and I'm getting right at 47 mpg.
Daytripper is offline
post #52 of 60 (permalink) Old 05-04-2010, 01:40 PM
Mac84's Avatar
http://www.fuelly.com/driver/mac84/vulcan
Mostly city riding, and I like to put the "pedal to the metal" a lot.
2006 VN750 acquired March, 2010, 19,544 miles
Currently 20,147 miles (5/1/2010)
Splines lubed
R\R relocated
Deka MF AGM ETX15L
Iridium spark plugs
Pirelli MT66 tires 110 front 150 rear
Speed bleeders
Mac84 is offline
post #53 of 60 (permalink) Old 05-08-2010, 02:41 PM
flitecontrol's Avatar
Discovered something on my recent ride to Missouri and back. I normally get around 48 mpg riding locally at speeds 55 and under. On the interstate, it goes down to as low as 35 mpg if I get above 75 mph.
There was a very stiff wind from the NW that was gusting so hard it would blow the bike all over the place. Noticed that when a semi passed me that the turbulence it created was much less than the wind buffeting, so I stayed in his wake until I had to exit for gas. Repeated the procedure until I got to my destination. When I was behind semi's, doing 70-75 mph, I was getting 50-52 mpg!
Anyone else had similar results?
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #54 of 60 (permalink) Old 05-08-2010, 02:58 PM
IMBoring25's Avatar
I enjoy striving for better gas mileage, but I would never draft a semi in a car, never mind a bike. The restricted visibility and maneuvering space on a public road are just too risky.
IMBoring25 is offline
post #55 of 60 (permalink) Old 05-08-2010, 05:24 PM
OldBikeNewRider's Avatar
I've been getting between 47-50. And I like going through the gears!
1986 VN 750
20,000 miles
Replaced Stock Turn signals
Starter Clutch
NGK plugs
MT66 Pirelli's
Seafoam
OldBikeNewRider is offline
post #56 of 60 (permalink) Old 05-08-2010, 05:58 PM
Redneck on a rice burner
Wileysden's Avatar
Location: American by birth,Southern by the grace of God ..,.AMEN !
Life is short WTF ! I drafted a semi from Ga. to Ms. & Ga. to & from Fla. ,speed up to 100. Dumb......ya, But I was young & Dumb too. I've had the police after me on 85n from Downtown to Buford @160mph + {not the vn750,on a gsx/R 750} That put me in "Prison Work Camp" for DUI,Racing,Pissing off cops,Ect....for 180 days in '89.... The good o'le days. I'm a cruser now/But would still DRAFT if on the highway!
Wileysden is offline
post #57 of 60 (permalink) Old 05-08-2010, 06:47 PM
I understand. I've seen folks in cages drafting semi's so close if the semi touched his brakes they were gonna make contact before the drafter could slow down. Had a guy in a pickup decapitate himself on the local Interstate a couple of years ago drafting a semi.
I kept two seconds following distance and was extremely alert for tire chunks and other things that might come my way. I felt it was better to be behind the truck where I could control the bike better than to have the wind push me into a cage. There is more maneuvering space on the Interstate (which is what I was traveling) than most other roads.
"Black Beauty"
Old Blue
post #58 of 60 (permalink) Old 05-09-2010, 01:12 AM
skalding's Avatar
Basic Aerodynamics. In your case you were riding in the "wake" of the truck and thus had to expend less energy to push the air out of your way.
Here's a guy to took the design to it's logical end. http://ecomodder.com/blog/diy-aero-f...cycle-214-mpg/
Scheherazade
'86 VN750
MF Battery, Iridium Plugs, RR relocated, Voltmeter, 170/80/15 Kenda Kruz rear tire, DIY Samsonite hard bags, DIY shaved seat with Beaded seat pad ('cause that's how I roll) and the dreaded STATOR CHANGE.
Shining Black Bess '86 VN750, retired for parts after a fried stator and being knocked (kee-runch) in her parking spot.
skalding is offline
post #59 of 60 (permalink) Old 05-09-2010, 01:38 AM
dirtrack650's Avatar
Try a tanker
I draft at a safe distance with tanker trucks. They seem to have a cleaner wake and you don't need to be as close to a 'van' box. It makes a big difference with my GL500.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #60 of 60 (permalink) Old 05-09-2010, 11:32 AM
MANIC MECHANIC
vulcanjoe's Avatar
there is a speed limit on I85 when we were down there building phillips arena i was doing 80-90 mph and people were still passing me like grandma in the slow lane.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
