suddenly stopped running - - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 05-01-2008, 04:06 PM Thread Starter
Hi: i have yet to do any investigation as it happened on the way to work, and i had to just park and walk home to grab the car.
But this morning, she fired up fine and i drove about 5 blocks and then a truck was turning around in the street and traffic was all blocked up: I stopped and waited for about 30 seconds, then decided it was going to take too long, and started to turn around to take another street: it felt almost like i was in too high a gear as i turned- sort of bogging down. by the time id completed the turn, the bike had stalled.
I had been in 1st gear. I restarted- it idled but any gas and it stalled. i did it several times, switched to the reserve tank - but pretty soon it would not start at all ( i have half a tank of gas)
I am figuring something got stuck in the fuel line or something, but wondered if there is something else that you guys might know of that could cause this.
jetboy is offline
post #2 of 7 (permalink) Old 05-01-2008, 04:07 PM
Elemental's Avatar
https://www.vn750.com/forum/showpost....0&postcount=13
1990 Vulcan
Saturn Plum/55 Tbird red.
Accel Coils.Mangacore wires.Corbin Seat.
Cobra exhaust.Jetted to 1.1 lamda.
Wide levers,cushy grips, All steel lines....
Actually, I've changed more stuff then I can remember.
Elemental is offline
post #3 of 7 (permalink) Old 05-01-2008, 04:31 PM
99vulcan750's Avatar
mine did that today.. same thing..
'99 VN750 with 8900 miles and growing (3,111 when I bought it 03-22-08)
Ear shave with Unipods
Drilled mufflers and degoat
TOC springs
N/C Street shield EX windshield
Jumbo Saddleman Highway Studded saddlebags
Willie and Max Saddlebag mounting kit
License plate turn signals
Home made sissy bar
Luggage Rack from Scoop
http://youtube.com/user/99vulcan750
99vulcan750 is offline
post #4 of 7 (permalink) Old 05-01-2008, 04:38 PM
all of this is true. meanwhile there are simple things that causes the problems sometimes, while i was working main. for a school district, i had a bus stall out on a trip. retreived the bus , trried to replicate the problem, driving etc, changed fuel filter checked drive test, no problem. sent it out on long trip stalled, problem, blocked fuel tank vent, only showed up on constant drving 20 miles or more.. check your fuel vent. ride safe
aradams is offline
post #5 of 7 (permalink) Old 05-01-2008, 04:56 PM
Elemental's Avatar
Short cuts are a slippery slope. Trying this and that often gets many uneeded aprts and lost time.
Using a consistant preceedure for diagnosis saves time and money. Also, with a firm grasp on the fundimentals you can walk up to ANY gasoline 4 stroke engine and figure out whats wrong.
1990 Vulcan
post #6 of 7 (permalink) Old 05-01-2008, 05:51 PM Thread Starter
yeah well: looks like the 81 440 ltd is going to get a work out until i figure out whats up. its usually the problem bike, not the vulcan- a year and a half and not a single issue with the vulcan until today: I just got a filter and was going to do the oil this weekend.
jetboy is offline
post #7 of 7 (permalink) Old 05-01-2008, 07:11 PM Thread Starter
update
Got home, walked down to her 0- she started right up and i rode home. no problem.
SO its one of those pesky type of problems. i still suspect fuel due to the nature of the shut down- so may be time to change some lines and filters and drain the tank -
jetboy is offline
