Stock jet sizes? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 04-30-2008, 06:47 AM Thread Starter
750Doug's Avatar
Stock jet sizes?
Anybody know what the stock jet sizes should be on an '88 750? I just spent some time searching, and I'll I keep finding is what to change to, when doing the ear shave.
Something around 38 and 132 maybe?
TIA.
750Doug is offline
post #2 of 9 (permalink) Old 04-30-2008, 11:54 AM
93VN750's Avatar
Those are the stock sizes.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 9 (permalink) Old 04-30-2008, 06:09 PM Thread Starter
750Doug's Avatar
Sweet. Thank you!
750Doug is offline
post #4 of 9 (permalink) Old 04-30-2008, 07:40 PM
Hey went to get jets for my 89 last week and the guy ask me if they were round or flat but I haven"t pulled the carbs yet with all my other issuesCan anyone help???
Korr is offline
post #5 of 9 (permalink) Old 04-30-2008, 08:41 PM Thread Starter
750Doug's Avatar
Mine are round, maybe a 1/16th or 1/8" dia, with flat tops, and a slot for a straight screwdriver.
750Doug is offline
post #6 of 9 (permalink) Old 04-30-2008, 09:01 PM Thread Starter
750Doug's Avatar
Maybe this will help a little more...
750Doug is offline
post #7 of 9 (permalink) Old 05-01-2008, 09:42 AM
Thanks!!!!
Korr is offline
post #8 of 9 (permalink) Old 05-01-2008, 01:10 PM
Too bad that wasn't a little clearer. With labels & descriptions &... Yeah. One of those days.
post #9 of 9 (permalink) Old 05-04-2008, 10:39 PM
How 'bout this?:
1) The larger one to the left is the main jet. Use a 10mm wrench to hold the jet seat, while you unscrew (or screw in on reassembly) the jet with a flat blade screw driver that fits the slot. If the carbs are still in the bike, you can remove the jet seat with a 1/4" drive socket, then remove and replace the jet.
Stock main jet is usually a 132 on the 750; 135 on the '85 VN700, altho some later 750s came with 135s, also, depending on where they were sold.
2) The smaller slotted jet in the middle is the pilot. It can be removed from the carb with it still on the bike with a right angle screwdriver, or a screwdriver bit in a 1/4" wrench. Takes a bit of maneuvering to get it back in; the bit in the end of a piece of vacuum hose helps get it started and snugged, then the bit in the wrench to tighten--gently.
Stock pilot is 38, no matter what year or where it was sold.
3) The one on the right is the air jet. It's press fit, and ain't removable. If it's stopped up, the bike will run like crap. Do not use anything larger than a single straight bristle off a brass wire brush to clean it out, and the only safe way to do that is with the carbs off the bike.
hth
Jim
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
