What could be causing this? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-29-2008, 09:51 PM Thread Starter
My 750 idles great (no back fire when you crack the trottle) and runs smooth to about 4.000rpms . Then between 4,000 and 5,200 rpms it breaks up and after 5,200 rpms it smoothes out again and runs like a screamer. What could be causing this? Thanks for any help in getting this situation straightened out.
ride safe, J
free wheel-e is offline
post #2 of 6 (permalink) Old 04-30-2008, 05:47 AM
Could be sticky floats in the carb
terryuk is offline
post #3 of 6 (permalink) Old 04-30-2008, 01:14 PM
Search Goddess
Dianna's Avatar
Also check the tube in your right air filter (the ear) Could be the imfamous blocked tube stumble from the tube bottoming out against the case.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #4 of 6 (permalink) Old 04-30-2008, 01:35 PM
Elemental's Avatar
You have a fuel induction problem. Its not a sticking float, but I would bet you have a clogged jet.
This bike would likely benifit from a carb disassemble and clean.
1990 Vulcan
Saturn Plum/55 Tbird red.
Accel Coils.Mangacore wires.Corbin Seat.
Cobra exhaust.Jetted to 1.1 lamda.
Wide levers,cushy grips, All steel lines....
Actually, I've changed more stuff then I can remember.
Elemental is offline
post #5 of 6 (permalink) Old 05-02-2008, 12:03 PM
runs great at 1000rms anything above nothing
i just bought a 1994 vulcan 750, great deal but has been sitting since last summer. changed the plugs battery dumped old fuel, replaced with new and replaced fuel filters that ar a pain in the &*%$#. bike fires right up but when you give it any gas at all it chokes off. when i pull my carbs i am wondering if i should jet since it will be off and is there a rebuild kit or do you just take off clean and put back on
need help please
VN75008 is offline
post #6 of 6 (permalink) Old 05-02-2008, 12:40 PM
need help please
A good cleaning should fix that up, I wouldn't rejet unless you have to. Even sitting for a winter can cause the tiny little passages in carbs to plug up which can cause all kinds of problems
85 VN750 basketcase ( yes its a true 750, and no smog controls, its good to be Canadian)
It will have
a rebuilt 96 top end, rebuilt 85 bottom end
degoated, Eared
stripped, lowered, raked, bobbed,
reed valve boxes shaved
ported and polished
balanced
right side dump exhaust
heads and cylinders shaved for compression
looking for smoothbore sidedraft carbs
possibly fat bob tanks
modified vn800 or sportster drag pipes or I'll just make some
Chopperfix
Duck's Garage
Duck is offline
