Still have carb issues, I think? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 04-29-2008, 02:23 PM Thread Starter
I just had my carbs off and cleaned, nothing was broke. Did find something in the one carb making the float stick. Cleaned them and put them back on bike and took it to a shop and had them resync the carbs. Now it starts great and idels fine but going down the road between 4-5ooo rpms it surges. Give throttel or slow down and it seems to run smooth. What do I look for now? I check for leaks around the boots and hose while it sat ideling with carb cleaner like was suggested and found none and I'm quite sure everything is hooked up right. I would be really greatfull for some ideas or suggestions as to what to look for or do next. Thanks!
Mark A. Gurnsey is offline
post #2 of 2 (permalink) Old 04-29-2008, 07:27 PM
93VN750's Avatar
Make sure the carb vent line is not bottomed out in the right ear. A 45 deg cut at the end will insure that's not the problem.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
