Low idle speed / gas on plugs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 04-22-2008, 08:22 PM Thread Starter
Unhappy Low idle speed / gas on plugs
I have been experiencing a problem with my 93 VN750. I began to experience idle speeds around 1000 RPM when coming up to stop lights. If I had to sit for any length of time, I had to keep the idle going. Thinking it was the ignition coil acting up on the front cylinder, I replaced the it. After seeing gas on the plugs, I thought they weren't getting spark. Things ran good for 2 days and the low idle is back, along with gas on the plugs (new ones). I checked the plug wires and they all run spark through them. Once I get going, the bike runs fine. Anybody got an idea what it could be?
Dennis Larson is offline
post #2 of 2 (permalink) Old 04-22-2008, 10:37 PM
Rider of Lightning
Could be a stuck choke or float in just one carb. I'd run seafoam through it, and get some carb cleaner, spray it into the carb mouth while the bike is running....and don't let the bike die, so you will need to give it some gas.
Also, you could try the burping method. Just search for it and you will find a good explanation.
Good luck.
Bobby in Lakeland, FL
1994 Vulcan 750
Drilled 8 holes in exhaust and love it
Coasters and love it too
NGK boots and new wires
NGK Iridium Plugs
Bought 3/08 with 35000
99% stock, but working on it
scuba69diver2 is offline
