marbling - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 04-10-2008, 12:37 PM Thread Starter
99vulcan750's Avatar
marbling
ok, I am going to marble today..
I just want to make sure I got the right hoses...
Here's the right side/front cylinder:
and the left side/rear cylinder:
put the marble in just at the end of each hose and I'm good right? and then adjust the air mix screws... Correct me if I am wrong, thanks!
'99 VN750 with 8900 miles and growing (3,111 when I bought it 03-22-08)
Ear shave with Unipods
Drilled mufflers and degoat
TOC springs
N/C Street shield EX windshield
Jumbo Saddleman Highway Studded saddlebags
Willie and Max Saddlebag mounting kit
License plate turn signals
Home made sissy bar
Luggage Rack from Scoop
http://youtube.com/user/99vulcan750
99vulcan750 is offline
post #2 of 8 (permalink) Old 04-10-2008, 04:58 PM
Shove the marrble into the hose and reconnect the hose. Adj. fuel mix and you should be okay.
post #3 of 8 (permalink) Old 04-10-2008, 08:25 PM Thread Starter
the hose doesn't want to come off to put the marble in.. Any ideas?
TOC springs
Home made sissy bar
post #4 of 8 (permalink) Old 04-10-2008, 09:22 PM
Remove the clamp and then take a pair of pliers and without damaging the hose, twist the hose to break the seal. This should make it come a loose.
post #5 of 8 (permalink) Old 04-28-2008, 06:22 PM
where are the fuel mix screws located...are they the little straight blade screws that i see near the bottom on the carbs?
james
james shaw is offline
post #6 of 8 (permalink) Old 04-28-2008, 06:35 PM
oglejust's Avatar
oglejust is offline
post #7 of 8 (permalink) Old 04-29-2008, 01:03 AM
james
You may have to remove the lead plugs that covers them so that you and I won't mess with them.
post #8 of 8 (permalink) Old 05-02-2008, 02:34 AM
yep, them are the ones, make sure you know how much you adjust them down to the 1/4 turn
snake is offline
