A/F Adjustment - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-06-2008, 02:01 PM Thread Starter
Gadget35's Avatar
Send a message via MSN to Gadget35
A/F Adjustment
I was reading adjustment of carb needle valve which i think i have identafied but all the pics from form that showed location do not work anymore any one have a current picture of this i can view. And also info on performance is there a performance gain adjust to a richer mixture?
Gadget35 is offline
post #2 of 6 (permalink) Old 04-06-2008, 03:53 PM
Dianna posted a couple pics in the gallery here.
Here they are....
Left:
Right:
I haven't done anything to mine, but I believe the only thing adjusting them does is help eliminate decel popping and nothing for a performance gain.
post #3 of 6 (permalink) Old 04-06-2008, 05:24 PM
Yes, it increases horsepower by .002%, and let the bike run .03% cooler at idle.
post #4 of 6 (permalink) Old 04-06-2008, 08:24 PM
Is that metric horsepower or english ??
post #5 of 6 (permalink) Old 04-06-2008, 09:53 PM
is there a certain rule of thumb on how to adjust them? mine pops when you get off the throttle almost like a back fire. ? any suggestions
great 1 is offline
post #6 of 6 (permalink) Old 04-07-2008, 08:57 AM
There are several things that cause the pop sound....First is a leaking exhaust gasket. Second is a lean condition which can be adjusted by the fuel mixture screws you are asking about. They should be turned in until they bottom out (gently so as not to damage the seat) then turned back out anywhere from 2 to 3 full turns. There is one on each carb as shown in the pictures. The third is the emission control stuff on the bike. You can block these with the marble trick or coasters. There is info for this in Vulcan Verses as well as multiple threads here. Hope this helps.
And KM, I believe your calculations are off a bit. I got a HP increase of .003% and my bike runs .05% cooler. Perhaps the extra .00000001% of a turn I gave my screws is the difference. You need to readjust yours....lmao.
scuba69diver2 is offline
