Switching out gas tanks - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 03-29-2008, 12:18 PM Thread Starter
Joem's Avatar
I have a new gas tank on the way. Mine has rust on the inside, not enough to have caused me any problems yet, but It's been a bit of a worry. The new tank is also a different color scheme, and I have been wanting to get rid of the teal. The one I bought is supposed to have been taken off a new 2000 or 2001 and put on a 93, which then died and got parted out. He said it only had fuel in it for a few days. I am holing it is in as ggod a shape as he said. The new color is black and charcoal silver. I have chrome side covers already, so the only other teal parts are the fenders, which I bet I can get painted fairly cheaply. I may just sand them and spray paint them gloss black.
Anyway, how hard is it to switch the tanks out. Are there any hoses or anything else that I will need to replace?
Joe McAdoo
Springfield, MO
[email protected]
VROC # 28175
Joem is offline
post #2 of 10 (permalink) Old 03-29-2008, 02:35 PM
I'd go ahead and replace the hoses, vac and fuel, since the tank is gonna be off anyway. That way you'd know they're all good.
Pulling the tank is pretty straightforward. Pull the hoses off the petcock, pull the seat, then undo the three bolts holding the tank on the frame, and pull the tank up and back. Swap the petcock over to the new tank.
To replace, reverse the process, being sure to get the tank dampers lined up properly.
I might be interested in your old tank, if the price was right.
Jim
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
post #3 of 10 (permalink) Old 03-29-2008, 02:42 PM
Chucklehead
dragon159's Avatar
Three bolts, a couple hoses and the wiring for the fuel guage. I think the hardest part is removing the seat lol.
dragon159 is offline
post #4 of 10 (permalink) Old 03-29-2008, 04:59 PM
HAWK
Ccspinner's Avatar
Make sure you get the gromets back in the way they came out.
If you do not get them in right and tighten to tight you can crack the tabs off the tank.
Other than that it is easy.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #5 of 10 (permalink) Old 03-29-2008, 05:23 PM
Growling at the World...
bulldog485's Avatar
Send a message via Yahoo to bulldog485
I would also replace the gaskets too. One of those "while you are down there" things...
Evan Breyn ~ The Bulldog
http://www.bulldogsbike.com
2006 Harley Davidson Ultra Classic FLHTCUI ~ The Big Black Bitch ~ 26,000 miles.
2002 Kawasaki Nomad 1500 ~ The Red Dog ~ Traded in at 22,000 miles of smiles (purchased new 10/05 / Traded in 6/12).
1990 Kawasaki Vulcan 750 ~ Black Betty ~ 34,999.7 miles
VROC ~v~ 485
McHenry County Road Pirates
Chicagoland, IL
bulldog485 is offline
post #6 of 10 (permalink) Old 03-29-2008, 05:25 PM
bulldog485's Avatar
I had a mechanic do that for me once. Ended up being the excuse I needed to repaint the bike as the new tank didn't match the existing paint.
VROC ~v~ 485
Chicagoland, IL
post #7 of 10 (permalink) Old 03-29-2008, 05:25 PM Thread Starter
Joem's Avatar
Hey, thanks. I don't know what's going to happen with the old tank. My friend who bought the bike tvs587b had has a problem with his tank. For some reason it doesn't vent properly. Tim layed it down in a ditch, and had someone replace his dented tank with another used one. It has a different looking gas cap. I don't know if the tank presurizes or vaccuums, but when he get's low on fuel he has to open the tank to either let air in or out, not sure which, or his bike will die. We may try to treat the rust and put mine on his.
Joe McAdoo
Springfield, MO
[email protected]
VROC # 28175
Joem is offline
post #8 of 10 (permalink) Old 03-29-2008, 06:22 PM
Sky Rider's Avatar
Don't forget the rear lines on the tank!! If you have a CA bike, there will be two, if not it is just the fuel overflow.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #9 of 10 (permalink) Old 03-29-2008, 09:15 PM
It's creating a vacuum, and it's probably the vent valve in the cap; mine does the same thing sometimes. Easiest thing to do is get rid of the vent valve, altho I ain't gotten a"round to it" yet. Sometimes all it needs is cleaning out; you get the same gum/gunk in the vent valve as you do in the carbs.
Make sure the tube inside the tank from the cap vent to the drain tube is clear, too; blow some air thru it with the cap open.
I've come across two instances where the rubber grommet seal at the end of the tank tube, under the gas cap, was deteriorated enuff that a loose piece of it would block the vent, also.
Jim
J.D.
Kerrville, TX
aka "Raggedy Ann"
'95 VN750 project
VROC #16185
GCVROC #33
J.D. is offline
post #10 of 10 (permalink) Old 04-10-2008, 12:00 PM Thread Starter
Joem's Avatar
Now I have a question about replacing the petcock. It looks like on the new tank there is some kind of adhesive and/or seal where the petcock was. What is this stuff? I assume this will need to be used when I attach mine to the new tank.
Joe McAdoo
Springfield, MO
[email protected]
VROC # 28175
Joem is offline
