Fuel Sensor Float - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 03-25-2008, 04:03 PM Thread Starter
Fuel Sensor Float
I recently bought a '01 750 and have been doing some minor work getting it ready. I have a fuel gauge problem that I thought I had solved by replacing a shorted wire. Today I pulled out the sensor and the entire float is missing. They're not sold separate from the entire sensor assembly (~$60), which seems a little steep for just a missing float.
A couple questions:
1. How are the floats attached to the stem? My stem doesn't have threads or anything else that I can see.
2. Is the original one air-filled or a solid buoyant material?
3. Would it be possibly to rig a homemade float? Could I use a small plastic bottle? Is there a sealant/adhesive out there that won't break down in gas?
Thanks,
Tilak
tilak is offline
post #2 of 15 (permalink) Old 03-25-2008, 10:37 PM
Sky Rider's Avatar
The float is a solid type and seems to be mounted with some kind of adhesive. The float itself is only about an inch in diameter.
However, you may want to contact a salvage yard and see if they have a badly damaged tank that you can rob the sensor assembly out of.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #3 of 15 (permalink) Old 03-25-2008, 10:53 PM
If you have old parts like a lawn mower carb as such, you may be able to use the carb float for the fuel gage float.
post #4 of 15 (permalink) Old 03-26-2008, 09:58 AM
Kawika
davewex's Avatar
I believe JB weld has an adhesive product for fuel tank applications. I've seen it at Harbour Freight, Sears, Menards, etc.
I like niterider's idea for a float
I was thinking about those floater key chains for boat keys, but the foam may not be able to hold up in the fuel....then there is also round bobbers for fishing...
LETS RIDE!! VROC# 26137
☠ Black Candy ☠ '07 Mean Streak 1600
☠ Blue Crush ☠ '95 VN750-A11
davewex is offline
post #5 of 15 (permalink) Old 03-26-2008, 12:39 PM Thread Starter
Thanks for all the suggestions. I went out and bought a cork stopper at Lowes and some JB Weld to keep it from sliding up or down the metal stem. A mechanic told me that floats used to be made out of cork, so it should work. If not, I'll try the fishing bobber idea.
tilak is offline
post #6 of 15 (permalink) Old 03-26-2008, 04:59 PM
I have never seen a cork float for gasoline. I have worked on lots of junk. I am over 1/2 century old too. I would be afraid that it would break up and you will have another problem to add to the first one. Trash in the fuel lines and tank. Just my thoughts on the subject.
post #7 of 15 (permalink) Old 03-26-2008, 06:26 PM
liljd's Avatar
I have to agree with niterider, cork will degrade over time most especially in gas and will cause a huge prob for you. If you have ever seen an old cork from a bottle of wine it is broken in places and that will clog things up in the tank. Try the bobber as that may be the more prudent idea.
James
1985 vn700 (T'Plana)
Gremlin bell
HD-O shield
saddlebagged
custom made supports
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
Kuryakin battery gauge
and LED taillights
marbled
____________________
VROC #27169
Tn VROC #134
www.youtube.com/thetrueliljd
liljd is offline
post #8 of 15 (permalink) Old 03-26-2008, 10:12 PM Thread Starter
I had already JB Welded the cork in place when I got these. I did a little research online and found that cork was common float material in old cars (just google "cork fuel float"). To keep them from breaking down or getting saturated they were covered with a good coat of shellac. I found a product called Seal All that's gas and oil resistant, stated to work on carburator floats and gas tanks, so I coated the cork well in it. Keeping my fingers crossed . . .
tilak is offline
post #9 of 15 (permalink) Old 03-26-2008, 10:57 PM
If you develope fuel problems you will know where to look first. Good luck with this.
post #10 of 15 (permalink) Old 03-27-2008, 04:00 AM
liljd's Avatar
Good luck with it but just think about why it was used in "old cars" and not in new cars hehe. Has to be a reason it's not used anymore right? I wish you the best of luck and hopefully it will work. Fill us in as to how it works and keep us posted of any new developments. And be sure to keep an eye on it.
James
Gremlin bell
HD-O shield
saddlebagged
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
and LED taillights
marbled
VROC #27169
Tn VROC #134
liljd is offline
