Petcock shot - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 10-14-2014, 02:20 PM Thread Starter
Petcock shot
I have my '86 750 in a shop for a carb cleaning (it sat in a garage for about 25 years before I got it).
When they got that done, they found that the petcock was shot and that it was flooding the cylinders.
Here is the problem: they say that the part is no longer manufactured and are now looking for a rebuild kit.
Any ideas on sources for either of these?
Brian is offline
post #2 of 5 (permalink) Old 10-14-2014, 03:32 PM
ebay but the TW200 petcock works great.
http://www.amazon.com/Switch-Valve-P.../dp/B00AR9U9EQ
post #3 of 5 (permalink) Old 10-14-2014, 07:04 PM
On Ebay today:
http://www.ebay.com/itm/86-06-KAWASA...487048&vxp=mtr
http://www.ebay.com/itm/Kawasaki-VN7...059546&vxp=mtr
http://www.ebay.com/itm/18-6635-Kawa...720269&vxp=mtr
post #4 of 5 (permalink) Old 10-15-2014, 07:22 PM
rsavant's Avatar
The petcock won't cause flooding, it only delivers fuel to the carbs. If the cylinders are flooding, you have carb problems. You may need to rebuild the petcock too but that's not the primary problem.
"Katie"
2002 VN 750, stock except for accessories
Mustang seat
Super Bright LED brake strobe on trunk
About 25k miles
All drive train maintenance performed, drive shaft coupler replaced
Way more experienced at pulling VN 750 carbs than I ever wanted to be.
TOC ACCT rebuild kits installed
Pick up coil mod
Cooling system flushed, refilled with fresh coolant
Petcock rebuilt
VN sold, current steed Honda ST 1300
rsavant is offline
post #5 of 5 (permalink) Old 10-17-2014, 09:19 AM
Ceal's Avatar
Exactly.
Also, you can buy a new replacement from some online motorcycle parts stores, they're just quite expensive. There are also rebuild kits on eBay. However, look into using the TW200 petcock. Some of us have been using it with great success, and it costs even less than the rebuild kit for the VN750 petcock.
1985 VN700 unknown mileage (over 33K)
AGM Battery
Iridium spark plugs
NGK wires and caps
Ceal is offline
