Throttle problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 03-03-2008, 08:01 PM Thread Starter
Send a message via AIM to MikeyMike
Throttle problem
Sorry if this is in the wrong post in advance. I seem to be having a sticky problem...literally. When I roll the throttle back it doesn't automatically come back forward into the prone position. Any thoughts? I don't know too too much about the small things like this....HELP!....if you want to. :-D TYIA!
Mike
Media, PA
VROC # 19922
Saddlebags
ONE HECK OF A GOOD TIME!
Ride Safe
MikeyMike is offline
post #2 of 5 (permalink) Old 03-03-2008, 09:07 PM
Sky Rider's Avatar
Either you have a cable binding somewhere or the return spring on the throttle assembly on the carb has broken or your throttle return cable has broken. One of those 3 things ought to cover it though not necessarily in that order.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #3 of 5 (permalink) Old 03-04-2008, 07:32 AM
Crobins365's Avatar
I second Jim on that. The easiest thing to check is for binding where the cables go into the throttle assembly - sometimes the push cable (the one that should close the throttle) can get set in there kind of awkwardly, so look for a cable that's "slopped out" of its guide. Then check your push cable, per Jim, to make sure that hasn't broken or is binding somewhere. And then check your linkage spring - that part's a pain, but it's a definite possibility, especially if you did any carb work and disassembled the unit (been there, done that). Best way to check that before pulling the carbs is to pull the cables off and see if the linkage plate snaps back into place when you pull it forward.
Good luck!
C
Crobins365 is offline
post #4 of 5 (permalink) Old 03-04-2008, 10:08 AM
93VN750's Avatar
As many times as I have pulled my carbs, this used to be a problem.
Check the adjustment at the carbs for the two cables. I found that if one of them has too little free play that the throttle will stick open. I always check with the carbs in my hand before mounting them.
You could also check that your throttle cables are lubed.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #5 of 5 (permalink) Old 03-04-2008, 01:14 PM Thread Starter
Hey guys, thanks a lot for the response. I'm at school at the moment so I'll give a check when I get home and let you know what's up. Thanks again!
Mike
Media, PA
VROC # 19922
Saddlebags
Ride Safe
