re jetting after ear shave, what did you use - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 02-13-2008, 05:26 PM Thread Starter
ive read about the diffrent sized jets people have used. just trying to get some feed back about what size you used and where you happy with it after. like, was the proformance what you thought it would be. did it increase your top speed.
thanks for any help
evil russ is offline
post #2 of 7 (permalink) Old 02-13-2008, 07:37 PM
Scoop's Avatar
Hey, didn't see you had posted this in the carb section too. Here's my reply from the newbie section -
Originally Posted by Scoop View Post
I rejetted 42, 42, 140, 142.
It stopped the popping and backfiring on decel and it seemed to run smoother and stronger as compared to after the ear shave and before rejetting, maybe a tad smoother than before the ear shave as well.
As far a s top speed, I have never tested it either before or after!
97 VN 750
R&R Relocated
Degoated
Ears Shaved/Rejetted
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
32 Ford Model A Tail Light
Rear bobbed and hard-tailed!
Scoop is offline
post #3 of 7 (permalink) Old 02-13-2008, 08:25 PM
Do the two 42 jets go on the same carb??? And the other two go on the other carb??? Which go on the front carb and which go on the rear??
post #4 of 7 (permalink) Old 02-13-2008, 10:20 PM
Scoop's Avatar
Sorry, I should have specified. For the front carb I used a #42 pilot jet and #140 main jet and the rear carb got a #42 and a #142. The rear gets a bigger main jet because it tends to run hotter and a richer mixture will help it run cooler.
97 VN 750
R&R Relocated
Degoated
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
Scoop is offline
post #5 of 7 (permalink) Old 02-14-2008, 08:15 AM
I'm still working on my nonjetting shave. Everythings working out good so far, just got alot of polishing to do behind those old ears! lol
I should have answers of it working proper or not by the weekend.
post #6 of 7 (permalink) Old 02-15-2008, 10:19 PM
I'm running 140 mains, 40 pilots on both carbs, one shim under each needle. A/F mix screws are at 3.75 turns out on the rear carb, and 4 turns out on the front one. With and without one shim didn't make much difference; two might, but I'm in no hurry to play with it right now.
I could prolly improve things a bit more by going to 142 mains, but hey; I'm happy with it the way it is, and my mileage hasn't suffered that much from stock.
Jim
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
post #7 of 7 (permalink) Old 02-15-2008, 10:30 PM
What are the shims for?
