Ear shave aftermath - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 02-12-2008, 09:33 PM Thread Starter
Undercover Sportbiker
AJCruzin's Avatar
Thumbs down Ear shave aftermath
Let me apologize in advance for being so needy. Normally I'm a little more adept at problem solving, but I'm new to wrenching on bikes.
I recently completed the ear shave on my 96. In the process I pulled all the EPA / CA emissions, plugged the left vent on the tank (as you sit on the bike) and ran a new hose for the right vent under the bike. My problem now (will they ever end?) is that the vent tube is dripping gas. There is a spot on the newspaper I put down on Sunday about the size of a quarter. The tip of the hose is also moist. Any thoughts on this? My first instinct is maybe the gas cap is not sealing properly. Maybe?
AJCruzin is offline
post #2 of 9 (permalink) Old 02-12-2008, 10:03 PM
HAWK
Ccspinner's Avatar
Is the tank full, mine will do that if the tank is to full.
Expecally if you fill the tank on the centerstand and park it on the side stand.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 9 (permalink) Old 02-12-2008, 10:22 PM Thread Starter
AJCruzin's Avatar
Nope
Nope - in fact she's right at the little white line (on the gauge) that is the next up from the E line.
AJCruzin is offline
post #4 of 9 (permalink) Old 02-13-2008, 11:29 PM
Are you sure you plugged the right vent? I've got a CA tank at home, but can't get there from here right now to check it...
Jim
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
post #5 of 9 (permalink) Old 02-14-2008, 01:04 AM Thread Starter
AJCruzin's Avatar
Therein lies the problem. Some folks said plug the right vent and others said the left vent gets plugged. The coasters I got from SCP said plug the left vent and run the right one to the bottom. Some of the posts I read about fuel leaks said people had leaky O rings in the gas cap, but I have no leaks anywhere, so I'm skeptical.
AJCruzin is offline
post #6 of 9 (permalink) Old 02-14-2008, 08:04 AM
Post a pic please. I'm curious... the cali tanks are different? I only have one hose coming off the tank.
post #7 of 9 (permalink) Old 02-15-2008, 10:09 PM
Yeah, the CA tanks are different. On a California bike, both tubes off the tank go to the separator/return pump. The one going in the top comes from the vent at the cap; the one going in the side of the separator is the return line to the tank. When both have been removed, and the emission system pulled, unless you remembered to mark which was which...
Easy way to tell, is open the gas cap, then attach a hose to either vent tube at the rear of the tank. Blow thru the hose; if air comes out the opening at the rear of the filler cap opening, there's yer vent tube. If it doesn't, stick the hose on the other tube, and check it.
Jim
J.D.
Kerrville, TX
aka "Raggedy Ann"
'95 VN750 project
VROC #16185
GCVROC #33
J.D. is offline
post #8 of 9 (permalink) Old 02-16-2008, 02:47 PM Thread Starter
AJCruzin's Avatar
You know, that's why I like this forum. Even when the answer is simple, nd in this case, something I already knew but had not tried because I forgot about it, people are still very helpful. I opened my tank and blew into each of the vents at the bottom. One blew air into the tank - obviously the return line. One blew air into the vent ring at the top, obviously the pressure vent. And it was the left one that needed to be open, so of course, since I plugged the one on the left, which goes into the tank, no suprise gas was coming out.... BTW - the one that vents pressure (left on my bike) is the blue one. I would guess the blue stands for air, since the other one is red, which probably means fire. Thanks!
AJCruzin is offline
post #9 of 9 (permalink) Old 02-17-2008, 01:18 PM
Or know there's a simple way, but can't quite place what it was...
BTDT! My sister calls it Oldtimer's Disease; says I've got it bad. I told her it's hereditary; and she's not that far behind me!
Jim
J.D.
Kerrville, TX
aka "Raggedy Ann"
'95 VN750 project
VROC #16185
GCVROC #33
J.D. is offline
