Mystery hose - desperately need input - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 01-28-2008, 10:35 PM Thread Starter
Undercover Sportbiker
AJCruzin's Avatar
Exclamation Mystery hose - desperately need input
I've mentioned this in a couple of other posts about separate things, but this post is dedicated to my mystery hose. I popped the rear tank mounting bolt and lifted her up a bit to get a better view of the underside of the tank. What I found was that the hose is actually connected to a nipple at the base of the feul level sensor. See the pic below:
If you look at part 14090, that is the nipple it's connected to. The hose is the perfect size and just long enough to connect to the vacuum sync T fitting coming off the middle of the carbs. I'd really appreciate some input here folks. BTW - I have a CA bike. Thanks!
AJCruzin is offline
post #2 of 4 (permalink) Old 01-28-2008, 10:52 PM
From here it appears to be the perfect place to get air to the carbs that will have a constant pressure. It appears to have a notch for air flow. I would hook it up see how it runs.
However, I could not find that system in my manuel.
post #3 of 4 (permalink) Old 01-28-2008, 11:15 PM Thread Starter
AJCruzin's Avatar
Updated with pic of the tank
OK, I broke down and pulled the tank up high enough to snap a pic. It's a little out of focus but clear enough to get the gist. What kills me is this is not labeled in any parts diagrams or hose routing diagrams I've looked at.
The hose goes down and far left. The line going straight down is the fuel gauge lead.
AJCruzin is offline
post #4 of 4 (permalink) Old 01-29-2008, 12:16 PM
Drewfus's Avatar
I have also removed my tank and found the same hose connected to the tank. I beleive it's the breather hose off of the carbs. My manual states that this hose should be routed into the right air filter. I decided to keep it attached to the tank.
Drewfus is offline
