Hard Cold Start and Sea Foam - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 01-07-2008, 03:32 PM Thread Starter
Kawasaki_Kev's Avatar
Thumbs up Hard Cold Start and Sea Foam
Well, I bought some Sea Foam fuel additive and gave it a try in my bike.
The reason for trying it was that my bike was really, I mean really, hard to start when it was cold. Also, about everytime I let up on the gas I got a bunch of popping. I haven't even been through the first tank and most of the popping has stopped. I came home from work today and tried to start my bike. Wow, what a difference - started right up.
However, I will update this post after running Sea Foam through my bike a while longer. I did have two things not so good happen after adding the Sea Foam. 1) my bike stopped idling 2) once in a while after letting up on the throttle it was reving high. I am hoping this will pass. But for now I am just wow'ed at how easy my bike started today.
And the funny thing - I never heard of Sea Foam fuel additive before coming to this forum.
Kawasaki_Kev is offline
post #2 of 11 (permalink) Old 01-07-2008, 04:46 PM
Scoop's Avatar
Popping on decel is usually caused by running too lean. It's usually made worse by modifying either the exhaust or air filters (ear shave). If it still pops you might try backing out your mixture screws 1/4 turn at a time and see if it helps. Do you have any mods to your exhaust or air filters?
I tried Seafoam as well and although it helped, the improvements to mine was not nearly as dramatic as what you describe! Glad it worked so well.
97 VN 750
R&R Relocated
Degoated
Ears Shaved/Rejetted
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
32 Ford Model A Tail Light
Rear bobbed and hard-tailed!
Scoop is offline
post #3 of 11 (permalink) Old 01-08-2008, 12:50 PM
If this is the first time you used Seafoam , it is possible it "knocked loose" some crud in you tanks, which has now found it's way into your carbs.
Give it a couple of tanks to clear out.
The idle problem can be caused by this, but I would first adjust the airscrews out some like Scoop suggested, and I would also check to make sure all the carb boots are tight, as an air leak can do this too. Ride the bike until it is nice and warm , then , RESET your idle speed to 1100-1300 rpms.
If the "runaway" idle does not go away after doing all the above, it may be caused by something else..
post #4 of 11 (permalink) Old 01-08-2008, 06:59 PM Thread Starter
I have no modes to the exhaust or the air filters. Although I am thinking about replacing everything with a complete aftermarket exhaust system.
I started up better today then yesterday - hit the starter, give it some gas, and it's started...
post #5 of 11 (permalink) Old 01-08-2008, 07:05 PM Thread Starter
The idle is going well now - doesn't stall out or go high.
I have the idle adjusted at about 1100 at the moment.
I will check out the carb boots to make sure they are good and tight.
As far as the jets go - I will have to do some reading in my repair manual.
My dad seems to think the bike is set too rich also.
Thanks for all the help...
post #6 of 11 (permalink) Old 01-08-2008, 10:23 PM
Have you checked the sparkplugs? They might need changed.
But by the sounds of things, the bike seems to be doing better now
post #7 of 11 (permalink) Old 02-03-2008, 02:41 PM
medic274's Avatar
spark plugs
Definitely change the spark plugs. When I was having problems starting & running rough, tried the SeaFoam first, but ended up rebuilding the carbs. I left the plugs that I HAD JUST PUT IN and had never even run the engine for any length of time with, and still would not start. I put new plugs in, she started right up. For the few bucks 4 new plugs cost, it couldn't hurt. Apparently, they foul up something awful with SeaFoam.
medic274 is offline
post #8 of 11 (permalink) Old 02-03-2008, 04:21 PM
ptcbob
ptcbob's Avatar
Iridium Plugs are awesome.
Bob
ptcbob is offline
post #9 of 11 (permalink) Old 02-04-2008, 09:39 AM
Seafoam fouls plugs???
Medic,
Your comment re: Seafoam fouling plugs - where did you read/hear that? According to all the positive things I've read in here on Seafoam, and the people who are adding it to their gas every couple of tankfuls, I'm suprised it hasn't been previously noted.
jon
west chester, PA
newbie
jonathanrsr is offline
post #10 of 11 (permalink) Old 02-04-2008, 12:29 PM
Originally Posted by jonathanrsr View Post
Medic,
If the Seafoam got enough junk (mostly) dissolved in the fuel system, I would think it's possible for some of that stuff to foul the plugs.
Sure, the Seafoam is good stuff, but when there's a bunch of bad stuff in the system, it can still cause problems as it works it's way out. Just like it's been mentioned before about pieces of stuff plugging jets after a Seafoam treatment
