Where does this hose go? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 01-06-2008, 12:21 PM Thread Starter
Scoop's Avatar
You know the hose nipple at the rear of the gas tank? Mine never had a hose on it. Is this just an overflow or did this connect to something? Mine was marbled before I got it so I am not sure if this was connected somewhere before they marbled. Right now my plan is to just run a hose down and let it vent. Thanks.
97 VN 750
R&R Relocated
Degoated
Ears Shaved/Rejetted
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
32 Ford Model A Tail Light
Rear bobbed and hard-tailed!
Scoop is offline
post #2 of 7 (permalink) Old 01-06-2008, 12:24 PM
ptcbob
ptcbob's Avatar
Good question. Mine is missing also.
Bob
ptcbob is offline
post #3 of 7 (permalink) Old 01-06-2008, 12:42 PM
BMan23777's Avatar
On mine it is run down by the battery to the bottom of the bike as a vent line. The nipple runs inside the tank up to the gas cap.Run some mech.wire up through or down through from the gas cap side and make sure it's cleaned out.Mine was plugged and caused the bike to vapor lock and stall.
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #4 of 7 (permalink) Old 01-06-2008, 12:59 PM
93VN750's Avatar
Believe it is part of CA only emissions setup.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #5 of 7 (permalink) Old 01-06-2008, 03:34 PM
Search Goddess
Dianna's Avatar
CA emmissions tanks have two that feed into a canister and back.
All other tanks have the single vent and yes, usually have a hose on them so the gas is vented past the hot parts on the bike.
This becomes more relaveant during the summer when hot temps and a full tank will cause a bit of overflow.
Try and park in the shade right after a fill-up!
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #6 of 7 (permalink) Old 01-06-2008, 03:44 PM Thread Starter
Scoop's Avatar
Thanks to all for the info. Mine is a non-CA bike. I put a hose on it and routed it down but I think I need a little longer one to get it past all the hot parts!
97 VN 750
R&R Relocated
Degoated
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
Scoop is offline
post #7 of 7 (permalink) Old 01-07-2008, 08:28 AM
Just be sure that when you route the vent hose, it does not get kinked. Mine was when the bike was new and it did cause it to have a vapor lock problem and stall out. Since I rerouted the hose, no problems.
ratuck
Eldersburg, Maryland
2003 VN750
3500 Miles
MF AGM Battery
Willie & Max Compact Slant Bags
Saddleman Explorer Seat
Vance & Hines Cruzers
Kawasaki Rear Luggage Rack
Memphis Shades Shooter Windshield
Oversized Grips
Spline Lube
ratuck is offline
