adjusting choke cable - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 07-23-2014, 03:50 AM Thread Starter
my choke lever doesnt do anything anymore after i cleaned the carbs. how do i adjust it so it actually moves the choke. thanks
mattkimmons is offline
post #2 of 6 (permalink) Old 07-23-2014, 08:26 AM
are the forked levers that actually pull up the plungers installed correctly??
the only 'adjustment' is at the lever on left grip. as far as adjustment goes.. you adjust it like any other cable, with the desired results being when lever is pulled to full choke position, the plungers on carbs are fully extended.
michiganteddybear is offline
post #3 of 6 (permalink) Old 07-28-2014, 12:10 PM
This is a critical adjustment. There is no actual choke, it is an "enrichener circuit" just a hair off and it will run very badly or not run at all. If you had the carbs completely apart, and removed the rod that connects the plungers on both carbs, make sure you got it all back together right. When I had my carbs apart, by far the hardest part was reconnecting the rod and linkage to the rear carb. There was a spring, and several washers and plastic spacers, and a very small screw holding it all together. Not only was it difficult to put together, it was hard to hold together while assembling the carb halves.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #4 of 6 (permalink) Old 07-28-2014, 12:29 PM
+1 on that Jerry
post #5 of 6 (permalink) Old 07-28-2014, 01:01 PM
make sure it COMPLETELY disengages the enrichener circuit plunger
IMO the most important part is to ensure that when the lever on the left grip is in the "OFF" position, you need to ensure that the fork on the plunger is slightly seperated from the plunger. In other words, make sure the plunger is completely inserted and the fork has a very slight gap between the forks and the top of the plunger.
If it hangs up or the circuit is even slightly engaged, the bike can run poorly or stall out at idle.
post #6 of 6 (permalink) Old 07-28-2014, 02:23 PM
from personal experience, if one of them forks is incorrectly bent (they have some curve in them) it will cause issues with the plungers as well.. will pull them out at an angle instead of straight, or jam up when pulling out or pushing back in
