Position of petcock for fill up? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 11-26-2007, 02:18 AM Thread Starter
This is a newbie Q, so please bear with me. The last 3 times I've had to switch to reserve, it has been at 141 -142 miles. The most recent fill-up on reserve was at 173 miles - much more than it should have been, considering that the reserve is less than 1/2 a gallon and I have been averaging 47 MPG ( so an additional 24 miles max). At fill-up I turned the petcock back to "vertical" (pointing downwards), and expected to put in at least 3 1/2 gallons, but it took only 3 gallons. When on reserve and filling up, what position should the petcock be in - pointing downwards, pointing forwards (on reserve) or pointing back (closed)? Thank you in advance!
jon
west chester, PA
newbie
jonathanrsr is offline
post #2 of 9 (permalink) Old 11-26-2007, 09:56 AM
If I'm filling up after switching to reserve, I try to remember to put it back to the vertical (on) postion. Although, the position of the petcock wont effect how much fuel you can put in the tank.
Did you do much of any different riding (more low speed) at the 173 mile fill up than usual?
Also, if you have a nice tail wind, you'll get better mileage.
post #3 of 9 (permalink) Old 11-27-2007, 02:46 AM
I get bad gas mileage, but I have bad tail wind. LOL
post #4 of 9 (permalink) Old 11-27-2007, 10:15 PM
Sky Rider's Avatar
The position of the petcock won't affect tank capacity or gas mileage. All the reserve position on the petcock does is select a fuel pick up that is shorter than the regular fuel pick up to allow you to get the last 1/2 gallon or so out of the bottom of the tank. That's it. You could just run the entire tank in the reserve position with no problems whatsoever. (I've done just that when I forget to reposition the valve).
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #5 of 9 (permalink) Old 11-29-2007, 06:05 PM Thread Starter
mileage
Hyper - no significant difference re: driving that I can recall (super slab vs. back road twisties). What threw me off was that I had to switch to reserve at the "usual" mileage (141-2), drive a total of 173 miles, yet the tank took just slightly under 3 gals. I'm going to monitor it more closely.
Niterider - you might want to try Bean X for that bad tailwind *G*
Sky - thank you - that's how I thought it worked
jon
west chester, PA
newbie
post #6 of 9 (permalink) Old 11-30-2007, 02:59 AM
Maybe you had some stupid gas thief drain his gas into your tank, instead of your gas into his?! LOL
post #7 of 9 (permalink) Old 11-30-2007, 11:10 PM
james brill's Avatar
Do you fuel up with the bike on its' center stand or on its' sidestand? I think that the position of the handlebar with the sidestand down might also affect your fillup.
james brill is offline
post #8 of 9 (permalink) Old 12-01-2007, 03:25 AM Thread Starter
Hyper - don't think I didn't consider that! If I hadn't had the key in my possession all the time, I would suspect my buddies screwin' with me *G*
James - I always fill the tank when the bike is on the center stand, to be certain that I am getting the max fill.
jon
west chester, PA
newbie
post #9 of 9 (permalink) Old 12-01-2007, 07:52 PM
Heck, I am lucky to get 100 miles on the tank, but still has fuel sloshing and the bike acks like it is running out of gas!
vulcan750biker is offline
