engine revs when turn handle bars - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 11-22-2007, 02:07 PM Thread Starter
hi when i turn my handle bars to the right the engine revs its nuts off...any one any idea why and how to stop it...thanks
vtrkarl is offline
post #2 of 7 (permalink) Old 11-22-2007, 02:39 PM
BMan23777's Avatar
Check the routing of your cables.
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #3 of 7 (permalink) Old 11-22-2007, 03:44 PM
93VN750's Avatar
As Brian said, check your throttle cables, sounds like they are not routed right.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #4 of 7 (permalink) Old 11-23-2007, 12:49 AM
Now what
Ironman's Avatar
I had that problem early on--I was twisting the throttle as I turned the handlebars.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #5 of 7 (permalink) Old 11-23-2007, 10:04 AM
dirtrack650's Avatar
Cables and are you using stock bars or are they wide/taller? I put some tall pull back bars on my VN once and the only way I could avoid the problem was to route the cables outside the tank.
dirtrack650 is offline
post #6 of 7 (permalink) Old 11-26-2007, 04:45 PM
Check for idle screw adjustment...
I didn't know 'jack' re: the VN750 when I bought mine, so I didn't know the the idle screw adjustment was missing. When I turned the handlebars to the right, the revs would increase; when I straightened it out or turned to the left, no problem. That's when I also learned that sometimes you have to wait a while before a part arrives from Japan!
jon
west chester, PA
newbie
jonathanrsr is offline
post #7 of 7 (permalink) Old 12-04-2007, 11:29 AM Thread Starter
tks for replies now sorted
vtrkarl is offline
