Pod filters question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 11-15-2007, 10:22 AM Thread Starter
Lightbulb Pod filters question
So I was lookin at the listed pod filters for the earshave. The K&N and the UNI
And I was looking to see if I could find a better deal. I came across EMGO pod filters and was curious if anyone had tried them or knows if there are problems. You can see why I am asking below.
Z1enterprises
Emgo 54mm Pod filter EM12-55754 = $7.84each
http://www.z1enterprises.com/detail.aspx?ID=221
Auto Zone (may have to special order)
2 x K&N RC-2340 = $71.82 (not including local tax)
-or-
AJ USA (www.ajusa.com) 1-800-877-1911
2 x K&N RC-2340 = $58.70 (includes "FREE" shipping!!)
-or-
UNI PK-92 $37 2 in a kit
mstbone67a is offline
post #2 of 18 (permalink) Old 11-15-2007, 10:27 AM
93VN750's Avatar
Those are the ones I have, no problems with them.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 18 (permalink) Old 11-15-2007, 10:30 AM
I had to shim the rear of the tank with a few washers to make sure they cleared.
other than that they work good.
JamieB is offline
post #4 of 18 (permalink) Old 11-15-2007, 10:46 AM
Scoop's Avatar
I am using these as well. As JamieB said, you'll need to shim the rear of the tank about 3/8 to 1/2 inch to clear the tank on the left side.
97 VN 750
R&R Relocated
Degoated
Ears Shaved/Rejetted
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
32 Ford Model A Tail Light
Rear bobbed and hard-tailed!
Scoop is offline
post #5 of 18 (permalink) Old 11-15-2007, 11:50 AM
BMan23777's Avatar
That's what I have on mine too.
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #6 of 18 (permalink) Old 11-15-2007, 01:41 PM Thread Starter
That sounds awesome.. we need to update the earshave document with these emgo pod filters then.
Just trying to be thrifty.. ok cheap lol
post #7 of 18 (permalink) Old 11-15-2007, 02:28 PM
That is what I used too. Emgo.
post #8 of 18 (permalink) Old 11-15-2007, 03:48 PM
dirtrack650's Avatar
I use the UNI foam filter socks. Work great, no shims for tank needed $8.95 each. Work in rain too.
DT
dirtrack650 is offline
post #9 of 18 (permalink) Old 11-15-2007, 08:43 PM Thread Starter
what do you mean UNI foam filter socks Did you get the pk-92 or something different and add filter socks.
thanks
post #10 of 18 (permalink) Old 11-16-2007, 01:59 AM
Here's a pict of similar filters that I use. Pay the $50 if you want for K&N, these work great for $8.95 each.
http://www.650central.com/UNI_Pod%20...Stage%2003.jpg
Here's another source for foam socks. You can find these cheaper online. Nice thing is you can trim these to fit our tight quarters under the VN tank.
http://www.jcwhitney.com/autoparts/P...014691/c-10111
Last edited by dirtrack650; 11-16-2007 at 02:12 AM. Reason: link didn't work added new links
