Pod filters question - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 18 (permalink) Old 11-16-2007, 07:53 AM
Scoop's Avatar
Originally Posted by dirtrack650 View Post
Here's a pict of similar filters that I use. Pay the $50 if you want for K&N, these work great for $8.95 each.
http://www.650central.com/UNI_Pod%20...Stage%2003.jpg
Here's another source for foam socks. You can find these cheaper online. Nice thing is you can trim these to fit our tight quarters under the VN tank.
http://www.jcwhitney.com/autoparts/P...014691/c-10111
Do you have to oil these?
97 VN 750
R&R Relocated
Degoated
Ears Shaved/Rejetted
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
32 Ford Model A Tail Light
Rear bobbed and hard-tailed!
Scoop is offline
post #12 of 18 (permalink) Old 11-16-2007, 03:30 PM
dirtrack650's Avatar
Yes you do oil the foam lightly. Use the spray oil designed for foam filters or use lightweight oil. My filters are 7 years old and still look and work great. BTW when I purchased them they were only $5.95 each.
dirtrack650 is offline
post #13 of 18 (permalink) Old 02-27-2008, 11:17 PM Thread Starter
K got mine on.. yep need add a spacer to allow for the pods to fit. but looks good.
mstbone67a is offline
post #14 of 18 (permalink) Old 05-24-2008, 05:51 PM
the cheapos are great and i use them, but beware they are flimsy, can be bent, twisted easily, and i had the glue holding the bottom together fail on me once causing them to fall apart, but for the price they are fine
snake is offline
post #15 of 18 (permalink) Old 06-06-2008, 02:24 AM
oh by the way, my no name brand filters required I raise up the rear of the tank like 1 1/4"! Im thinking of getting some of them filter socks. Also I didnt jet my bike yet, (i have universal straight pipes too, no goat) and it runs ok. Im sure bigger jets will up the power though
snake is offline
post #16 of 18 (permalink) Old 06-06-2008, 02:59 AM
And lower the mileage but if you are running pipes and foam filters, you really need to jet. I use foam filters with a drilled goat and glass packs and plugs look good w/no backfire.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
post #17 of 18 (permalink) Old 06-22-2008, 06:13 AM
Wink Good writing
Keep up the good work!
gprunescaper is offline
post #18 of 18 (permalink) Old 07-02-2009, 07:14 PM
Ratbiker
groove_puppy's Avatar
Thinking about getting a couple of the Emgo pods. I currently use the Uni foam pods with the chrome caps but I like the look of the Emgo/K&Ns and I love the price of the Emgos.
Do you oil the Emgos and how often do you clean them?
Edit: Just received my Emgos from Z1 Enterprises. $8 each plus $6 shipping.
http://www.z1enterprises.com/detail.aspx?ID=221
groove_puppy is offline
