Tank Kreem opinion please - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 10-13-2007, 10:27 AM Thread Starter
dirtrack650's Avatar
I've never used it to coat the inside of a rusty tank. Does it work or does it mess things up? I have several vintage bikes that needs this treatment but I need to know real world usage before I attempt this. (it's not cheap).
Also, has anyone heard of using pure battery acid to boil out the rust in a old tank? an old timer here told me to put pure battery acid in the tank for a few hours to eat up the rust flakes that don't get washed out.
thanks,
Dirtrack
dirtrack650 is offline
post #2 of 16 (permalink) Old 10-13-2007, 01:42 PM
Do NOT use acid, it will just make things worse. There are two coatings on the market, POUR and KREEM...from what I hear, avoid KREEM.
Not sure if it is in the achives or Vulcan Verses, but there is a proceedure using electicity to clean out the inside of a rusty tank. An sure someone will come along and post the link or porceedure.
Other than replacing the tank, this is your best option...
post #3 of 16 (permalink) Old 10-13-2007, 04:02 PM Thread Starter
Thanks Knifemaker
Never heard of POR, VN750 and your comments helped me do the right thing without wasting money. My research showed that Kreem may not hold up to current fuel additives where POR can and is aircraft certified.
Here's a link for our members:
http://www.cbxmanmotorcycles.com/pro...d=4101&affid=4
Thanks,
Dirtrack
post #4 of 16 (permalink) Old 10-13-2007, 07:46 PM
The procedure was here in the Vulcan Verses:
http://tinyurl.com/39vz6e
post #5 of 16 (permalink) Old 10-14-2007, 01:22 AM
davros's Avatar
Send a message via AIM to davros
Here is the direct link for the POR-15 cycle tank repair kit. I used this kit on my tank and it did a very good job.
Bob
1992 Vulcan 750
Teal/Blue
13,000+ miles
Kawasaki Passenger Backrest
Kawasaki Rear Rack
National Cycle Plexifairing 3 Windshield
Küryakyn ISO Grips
Küryakyn Wide chrome Levers
Jardine Tapered Exhaust
Maintenance-Free Battery
Electrical Connection turn signal conversion
1984 GPz 750
Red
Project Bike
davros is offline
post #6 of 16 (permalink) Old 10-14-2007, 02:34 AM
Growling at the World...
bulldog485's Avatar
Send a message via Yahoo to bulldog485
I've never seen a Kreem treatment that held up. Usually causes trouble right away.
Evan Breyn ~ The Bulldog
http://www.bulldogsbike.com
2006 Harley Davidson Ultra Classic FLHTCUI ~ The Big Black Bitch ~ 26,000 miles.
2002 Kawasaki Nomad 1500 ~ The Red Dog ~ Traded in at 22,000 miles of smiles (purchased new 10/05 / Traded in 6/12).
1990 Kawasaki Vulcan 750 ~ Black Betty ~ 34,999.7 miles
VROC ~v~ 485
McHenry County Road Pirates
Chicagoland, IL
bulldog485 is offline
post #7 of 16 (permalink) Old 10-14-2007, 05:34 AM
Great artical' Thanks for shairing that. I've got an old honda 450 I used Kreem on and didn't like it either. On the 500 triple tank, I'll be useing the electric formula
Dave_Pa is offline
post #8 of 16 (permalink) Old 10-14-2007, 07:36 AM
2FAS4U
I just read an article in Motorcycle Cruiser magazine. They poured WD40 into a tank with a handful of 3/8" nuts, after removing everything and blocking the holes. Shook the tank for about 15 minutes, then flushed it with gasoline(or brake cleaner). They say it will remove surface rust and that the tank can be put back into service after making sure the screen is clean. For more severe rust, they recommended coating the tank, but didn't endorse any brands.
I had a buddy take his to a friends radiator shop, and they did it for him. Not sure which coating they used though.
2fas4u is offline
post #9 of 16 (permalink) Old 10-14-2007, 07:39 AM
2FAS4U
As far as the Por15 goes. I have many Hot Rodding friends that coat their vehicle frames with their product. Almost as good as powdercoating.
2fas4u is offline
post #10 of 16 (permalink) Old 10-16-2007, 02:01 PM
JamieB's Avatar
It looks like Por15 is the way to go.
My only question is can the Marine Clean and Metal Ready be poured down the drain or do I need to take special steps to dispose of it?
Jamie B.
Ankeny IA
88 Vulcan 750 with 40K+ miles
JamieB is offline
