When is a 750 a 375? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 70 (permalink) Old 05-28-2014, 01:15 PM Thread Starter
GloryRider's Avatar
So last night, I rode from work about 30 miles on the freeway doing an average of 70mph and then stopped at a grocery store to get some dinner. When I came out of the store, and cranked the bike up, it sounded weird, and sounded like only one cylinder was firing... I rode it about a half mile down the road to meet with some guys, and it had definitely turned into a 375cc! No good!
I don't know what happened since it had run perfectly from work to the store... I checked the spark plug wires, holding them up to the plug, and could see (and feel) plenty of spark from both of them... I checked the exhaust, and the front one is high pressure and hot, while the back one is lower pressure and cool air... no gas smell...
When I try to ride it, it obviously struggles to accelerate because of only one jug firing, but it also backfires like crazy... I'd have thought it's because of the fuel dumping into the rear exhaust and exploding, but that doesn't make sense since the rear exhaust is cool...
I "limped" it home about 5 miles or so, but didn't do any more diagnostics last night...
I posted this in the carbs/fuel section because I'm suspecting it's a carb issue, but wanted to see what y'all thought before I did anymore troubleshooting...
Thanks!
Matt
GloryRider
Atlanta, GA
Current Ride: 1995 Vulcan 88 (1500A9)
Purchased Dec. 2014
approx. 6,800 miles
Previous Bike: 2000 VN750 "Glory"
With homemade stator
Details on stator build here
"Four wheels move the body. Two wheels move the soul"
"You live more in 5 minutes on a bike like this going flat out than some people live in their lifetime." - Burt Munro
GloryRider is offline
post #2 of 70 (permalink) Old 05-28-2014, 01:19 PM
Well, isn't that an odd one. When you pulled the plugs did you see any wetness on the plugs in the cyl not firing? i.e. unburnt fuel? Was the spark the same color/intensity for both cyls?
I'd check all vacuum connections, and the carb boots. If you have a sync tool maybe see if they're severely out of sync?
post #3 of 70 (permalink) Old 05-28-2014, 01:25 PM Thread Starter
GloryRider's Avatar
I didn't actually pull the plugs yet... I just pulled the wires off to check for spark thinking the ignition coil might have gone out... The spark intensity was the same for both cyls, yes.
The vacuum connections are solid, and carb boots are on tight with no (apparent) leaks...
It's odd that it happened so suddenly! I mean, it was running perfectly, and then all of a sudden the rear cyl just quit workin!
I'm wondering if there's some piece of crap that got into the jet in the rear carb or something... maybe I should try Wolfie's blowback technique... I don't know how it could, since I have new fuel lines with filters on both of them... I guess it wouldn't take much to clog it though...
Hmm...
GloryRider
Atlanta, GA
Purchased Dec. 2014
approx. 6,800 miles
post #4 of 70 (permalink) Old 05-28-2014, 01:35 PM
The blowback is worth a shot. Quick and easy, with good recorded results.
I'd pull the plugs and make sure they're not wet. Would definitely narrow down if fuel was getting to them (even though you did not smell gas).
post #5 of 70 (permalink) Old 05-28-2014, 02:04 PM
x2 this is key here .....an absolute !
(Fuel or Electronic? )
post #6 of 70 (permalink) Old 05-28-2014, 02:14 PM
I would take the inline fuel filters out and fix the reason I thought I needed them.
wmsonta is offline
post #7 of 70 (permalink) Old 05-28-2014, 02:16 PM
That is a good note, why do you have in-line filters? It's not something I'd run, personally.
post #8 of 70 (permalink) Old 05-28-2014, 02:18 PM Thread Starter
GloryRider's Avatar
Honestly, they were there from the previous owner... I just left them on as additional protection from anything in the tank getting into the carbs...
GloryRider
Atlanta, GA
Purchased Dec. 2014
approx. 6,800 miles
post #9 of 70 (permalink) Old 05-28-2014, 02:19 PM
Pull the plugs, if they're dry.. remove the in-line filters and see if it solves the issue.
Seeing as its a vacuum based fuel system, and not pumped, filters can cause flow issues.
post #10 of 70 (permalink) Old 05-28-2014, 02:43 PM Thread Starter
GloryRider's Avatar
I'll give that a try tonight... thanks!
GloryRider
Atlanta, GA
Purchased Dec. 2014
approx. 6,800 miles
