Where is the Pilot Jet??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-24-2014, 02:27 PM Thread Starter
Forgive me if this has been addressed before. My 750 has been sitting for a year. I've replaced the battery and started riding again, but am having trouble with the bike not wanting to idle. I've turned the idle adjustment knob all the way to get the rpm up to 1100. Bike runs fine at residential/highway speeds.
I've read a lot about the pilot jet and wanted to remove/clean it to see if that would solve the issue. I'm not a mechanic and don't have any special tools, but thought I could do this if it were not too intensive.
Any help in locating and dealing with this issue is appreciated. If what I want to do is the wrong approach or too complex, knowing that before I start is also very much appreciated.
Jaffaj is offline
post #2 of 5 (permalink) Old 05-24-2014, 02:31 PM
Search the threads....perform Wolfie's back-blow ...it is not difficult.
Also, Seafoam can be your friend !
post #3 of 5 (permalink) Old 05-24-2014, 02:34 PM
Mountain Man
Spots's Avatar
Try some seafoam in the gas and backblowing the carbs first. Both can be found here, the backblow procedure is a sticky at the top of this section. If that doesn't work, you'll have to pull the carbs to get to the pilot jets. They are at the very bottom of the carbs inside the drain bowls.
"You cannot exaggerate about the Marines. They are convinced to the point of arrogance, that they are the most ferocious fighters on earth- and the amusing thing about it is that they are."
1993 VN 750 bobber/bagger mix named "Halfbreed"
Degoated
Turn signals deleted
Center stand deleted
Custom wrapped straight pipes
Ear Shave
NGK Iridium plugs
Mean Streak seat
MCCT conversion
Saddleman saddlebags
Spots is offline
post #4 of 5 (permalink) Old 05-24-2014, 03:26 PM
to answer the OP's question... the Pilot Jet is located inside the carburetor. the task of taking apart the carbs to clean them is easy in itself, getting the carbs out might be a little more frustrating. do as the previous people suggested.
post #5 of 5 (permalink) Old 05-24-2014, 10:18 PM
In the carburetor?lol.almost shot beer outta my nose
Tags
pilot jet idle clean
