Gas Tank Cap Makes Sounds After Riding - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 05-21-2014, 11:26 AM Thread Starter
Mod
Birdhunter02's Avatar
Have a 98 and changed tanks. Tank has a breather tube but the gas cap makes a whistling sound after a ride. I put the 98 cap on the tank that I think is from the late 80' or early 90's. Normal?
2003 1600 Classic
Sold
900 Seat Mod
Iradiun Plugs
V and H Cruzers
Windshield with Lowers
LED Tail Lights
Saddle bags
Chads Floor boards
Highway pegs
Birdhunter02 is offline
post #2 of 12 (permalink) Old 05-21-2014, 11:41 AM
..... Normal?
No..
wmsonta is offline
post #3 of 12 (permalink) Old 05-21-2014, 11:46 AM
Its venting. Open up the tank and I bet you'll hear the pressure release.
post #4 of 12 (permalink) Old 05-21-2014, 11:51 AM
Blow out that hose from the cap opening with your compressed air and disassemble and clean your cap.
post #5 of 12 (permalink) Old 05-21-2014, 12:14 PM
...thus avoiding a future POOGS issue also.
post #6 of 12 (permalink) Old 05-21-2014, 12:18 PM
Yep^ Mine did that, kinda whistles.Like the others said blow that vent line out and when you take the cap off to clean it If it has a spring in it cut one coil off and that will make it have less tension on it and it will open easier and not open and close rapidly and cause the vibrating or whistling sound. It is common on 1500 and 1600's.
You can fix it or just tell your buddies, it's happy ,that's why it is whistling
post #7 of 12 (permalink) Old 05-21-2014, 01:04 PM
Mine whistled when hot. It's normal, but may be an indicator of a future POOGS problem...heed he advise above.
post #8 of 12 (permalink) Old 05-21-2014, 02:37 PM
yup, plugged vent line (either the hard one in the tank assy, or the rubber one that connects to it).
just fixed same issue on mine (rubber one was plugged)
michiganteddybear is offline
post #9 of 12 (permalink) Old 05-21-2014, 06:08 PM
mine did that until I ruined the rubber diaphragm in the cap and removed it....now it works fine without the whistle.
post #10 of 12 (permalink) Old 05-21-2014, 10:41 PM Thread Starter
Mod
Would it cause hesitation at 60 mph? The bike is losing power at that speed.
2003 1600 Classic
Sold
900 Seat Mod
Iradiun Plugs
V and H Cruzers
LED Tail Lights
Saddle bags
Chads Floor boards
Highway pegs
