IT LIVES !!!( re: still puzzled ) - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 09-21-2007, 11:06 AM Thread Starter
Hey Everybody,
just an f.y.i., couldn't find time to pull the carbs myself, so I dropped of my bike at the local Kaw shop. They shimmed the jets and re-synched the carbs.. WOW!!!! what a ride. thanks to all of you who posted replies to help me !! you guys are the best. Now one last stupid question... on the rear shocks, how much air pressure should I run in them and on the " dail-a-ride" rear shocks, which number is firm, 1 or 4.
thanks again
Jerry
jprather is offline
post #2 of 8 (permalink) Old 09-21-2007, 12:05 PM
Spriddle's Avatar
Originally Posted by jprather View Post
Hey Everybody,
thanks again
Jerry
Rear shock air pressure: From what Ive read and others say on here, it should be 10 % of your weight. So if you weigh 200 lbs. put in 20 psi.
Be very careful airing them up,use a hand pump,you can easily blow the seals.
Dial-a-ride: 1 is the softest, 4 the most firm
Steve from Pittsburgh
2005 vn750
modified knifemaker driver boards
chrome levers, Shaved saddle
Ape manual CCT's, nylon saddle bags
engine mount covers, plexIII windshield
crash bar w/floor boards, air hawk pad
ear mod, rad cover/,w/ss mesh
chrome cable and wire covers
chrome anti-freeze cover
RR relocation,MF battery,drilled out
idle plugs,marbled
Spriddle is offline
post #3 of 8 (permalink) Old 09-21-2007, 12:35 PM
Scoop's Avatar
Hey Everybody,
thanks again
Jerry
If you don't mind, I am curious, what did run for the shop to set up the carbs? My local shop wanted over $300 to r&r and rebuild my carbs. Thanks.
97 VN 750
R&R Relocated
Degoated
Ears Shaved/Rejetted
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
32 Ford Model A Tail Light
Rear bobbed and hard-tailed!
Scoop is offline
post #4 of 8 (permalink) Old 09-27-2007, 12:39 PM Thread Starter
Hey Scoop
sorry so long in posting reply. it was 351.00 to re-do carbs.
jprather is offline
post #5 of 8 (permalink) Old 09-27-2007, 02:15 PM
93VN750's Avatar
Hey Everybody,
thanks again
Jerry
If you adjust the air pressure in the rear shocks, you have to use a zero loss pump. If you use a regular compressor, you may blow seals due to high pressure, and never get pressure right as every time to remove standard air chuck you will lose whatever you put in.
VERY low volume of air is needed.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #6 of 8 (permalink) Old 09-27-2007, 03:06 PM
dirtrack650's Avatar
Balance tube for rear shocks
Anyone build a balance tube for the rear shocks? I'm thinking about assembling one with a reservoir tank to cushion the rear more yet maintain pressure.
dirtrack650 is offline
post #7 of 8 (permalink) Old 09-27-2007, 03:22 PM
93VN750's Avatar
Here you go http://www.gadgetjq.com/airshockbalance.htm.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #8 of 8 (permalink) Old 09-27-2007, 03:58 PM
Benjammin'
BSkaggs513's Avatar
I had seen these air balance kits before (and lost the link- thanks), and am very interested in them. Has anyone used them and if so, what did you think?
This kit makes sure the shocks are the same pressure all the time. Anyone who has checked or tried to add air to each shock individually knows the headache of getting the air the same in each.
Anxious to hear feedback.
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
