Fuel flooding carbs & cylinder - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 09-20-2007, 10:07 PM Thread Starter
I'm the proud new owner of a 1988. Looks great with 22K miles. Got it cheap since it doesn't run. Hope it's a minor problem. Anyway, here's the scoop. The prior owner said it ran fine until recently. The last time out it started and after several miles stalled. Upon exam, he found the carbs and cylinders flooded with gas. I saw another post ("Carbs dumping gas. help!" - Engine89) that seems to describe the problem. Looks like it was a problem with the petcock. Hopefully that's all it is. Any opinions or assistance would be appreciated. Thanks!
Big Rig is offline
post #2 of 11 (permalink) Old 09-20-2007, 10:36 PM
HAWK
Ccspinner's Avatar
There is probabley more than one problem.
The petcock may be leaking anf the floats may be sticking.
The floats have to be sticking, they hold the flow of gas back even with the petcock open.
I'm sure you have seen the great miracles of Seafoam talked about on hear, Easer to do than pulling the carbs.
If it doesn't work then you may have to pull the carbs anyway but it is a good start.
Check the plugs make sure they are not fouled, if it got that flooded they probabley are. Get a new batt and keep a charger on it if you are trying to start it alot.
Do not try and start for to long the starter will not last long if you hold it down to long, 10 seconds is as long as you want to try.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 11 (permalink) Old 09-22-2007, 02:49 PM Thread Starter
Thanks for the words of wisdom. We'll see what happens.
Big Rig is offline
post #4 of 11 (permalink) Old 10-07-2007, 06:31 PM
Basketcase
ive got the same problem. the petcock was leaking on the vac side so i opened it up and removed the guts and put a cover on the vac line on the carb. Im still dumping fuel into the cyls. also getting fuel out the line that slips in behind the right hand ear. Stuck floats?
newvn750owner is offline
post #5 of 11 (permalink) Old 10-07-2007, 08:13 PM
Crobins365's Avatar
Sounds like it. Have you given it a good dose of Seafoam yet? It cures a lot of ills - not all, but a lot.
C
Crobins365 is offline
post #6 of 11 (permalink) Old 10-07-2007, 08:34 PM
Basketcase
getting the engine to run has been troublesome thus far, so I havent gotten to the sea foam just yet. Have a can on standby though.
post #7 of 11 (permalink) Old 10-07-2007, 10:16 PM
engine89's Avatar
Do yourself a favor and pull the carbs clean them and check the float levels. Also carefully take the petcock apart and clean it. When you are done cut an angle on the vent hose before putting back in ear. Worked great for me. Seems like more work than it is.
engine89 is offline
post #8 of 11 (permalink) Old 10-07-2007, 11:05 PM
Basketcase
Yeah thats what im leaning on doing. Might as well shave the ears since im going into the carbs anyway. Simplify
post #9 of 11 (permalink) Old 10-10-2007, 12:53 AM
Basketcase
I had a full 1/4 inch of sticky red stuff in the bottom of the bowls. Kinda nasty. Thanks yall
post #10 of 11 (permalink) Old 10-10-2007, 08:49 PM
Sky Rider's Avatar
That could cause the floats to not seal if any of it got in the valve seat or even stick so they couldn't seal. Either way, with that much gunk, Seafoam probably wouldn't have been able to deal with it.
If you do the shave, I believe you will need to rejet the carbs.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
