Reinstalling carbs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 26 (permalink) Old 04-30-2014, 02:05 PM Thread Starter
CPIntruder's Avatar
Reinstalling carbs
Hey guys. After having my carbs out for a cleaning I am trying to reinstall these guys. For the life of me I can't seem to get them squeezed back in. So, I'm thinking of removing the airbox to get better access. What needs to come off to get this airbox out, temporarily? is there a procedure listed here somewhere? Please don't refer me to the Clymer manual as it is less than useless.
Thanks in advance
Don
Four wheels move the body. Two wheels move the soul.
CPIntruder is offline
post #2 of 26 (permalink) Old 04-30-2014, 02:13 PM Thread Starter
CPIntruder's Avatar
Just to clarify, I don't need to remove the surge tank, just get it up higher than it is.
Don
post #3 of 26 (permalink) Old 04-30-2014, 02:33 PM
Then pull the ears off and lift the surge box up. You can zip tie it up or do what I do and wedge a piece of flat stock under it to hold it up.
post #4 of 26 (permalink) Old 04-30-2014, 02:42 PM
From memory, Spockster did it and documented it.
i trust my memory, not sure anybody else should.
wmsonta is offline
post #5 of 26 (permalink) Old 04-30-2014, 03:16 PM
The trick to getting the airbox out in one piece is to unhook the wiring harness and pull the harness out of the frame. Then the airbox can slide back and out, you still have to flex it some. It won't go out the front.
post #6 of 26 (permalink) Old 04-30-2014, 03:53 PM
Cut that sucker up and out and throw it in the trash. Took me two minutes to get my carbs back in without that in the way.
post #7 of 26 (permalink) Old 04-30-2014, 05:40 PM Thread Starter
CPIntruder's Avatar
Well, finally got these bitches back in, what a chore. I've worked on lots of bikes and carbs and I've never had so much trouble getting carbs in and out, what a design. Obviously meant to be done by 12 years old girls with tiny fingers in Japanese sweat shops. Makes Suzukis seem like a walk in the park, which is going some. Anyways, it's done and I won't do this again until I rebuild that parts bike. Even then, I'll install the carbs before the engine goes in the frame.
Don
post #8 of 26 (permalink) Old 04-30-2014, 05:47 PM
Don
Ever do a gl 1000's carbs?
post #9 of 26 (permalink) Old 04-30-2014, 06:42 PM Thread Starter
CPIntruder's Avatar
No. But I was thinking of buying a V65 Magma. Their carbs are in the same area and apparently a real bitch to work on too. I'll probably pass on that one .
post #10 of 26 (permalink) Old 04-30-2014, 07:21 PM
Oh but they are quick
