The45 degree hose cut? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 04-13-2014, 09:40 PM Thread Starter
notmechanical
Is there any pics on here of the hose that your supposed to cut at a 45 degrees from the air box. Am ignorant need pictures. I searched on the site but nothing turned up picture wise.
chardcastle is offline
post #2 of 12 (permalink) Old 04-13-2014, 10:06 PM
Crowley
crowley1027's Avatar
The tube in question runs from a tee - two tubes come from in between the carbs and hook into a tee. The third hose runs to the right side air filter. That is the hose
crowley1027 is offline
post #3 of 12 (permalink) Old 04-13-2014, 11:21 PM Thread Starter
notmechanical
Ok
So the end to cut is the end going into the air box correct?
post #4 of 12 (permalink) Old 04-13-2014, 11:34 PM
Crowley
Yes.
post #5 of 12 (permalink) Old 04-14-2014, 09:44 AM Thread Starter
notmechanical
Thanks!
post #6 of 12 (permalink) Old 04-14-2014, 12:51 PM
I cut mine at a 49 degree angle. Because I like being different...
post #7 of 12 (permalink) Old 03-26-2015, 12:13 AM
Do I cut the hose right behind the tee? Or run down the length of the hose... I purchased a 92 750 with the ears already trimmed and the goat already removed ( pretty much running just first section of exhaust) and, of course, the stator already shot, seller didn't tell me, but tracked down original owner and he already installed the "stator kit" luckily, have spare battery and have enjoyed riding it around town but too lean, doesn't want to run we'll at all if I put anything at all on the air breather..
pez46 is offline
post #8 of 12 (permalink) Old 03-26-2015, 07:32 AM
Since you have an ear shave you are going to take that hose and put it up by the tank where it is out of the wind. Zip tie it to the frame so it doesn't move around.
post #9 of 12 (permalink) Old 03-26-2015, 05:09 PM
I had problems with the surge tank removed was causing turbulent air under the tank. Put the hose on the fuel sender nipple and everything was perfect.
smltownr is offline
post #10 of 12 (permalink) Old 03-26-2015, 08:41 PM
Concert connoisseur
wib714's Avatar
Here is a link to the write up!!!
https://www.vn750.com/forum/showthread.php?t=57369
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
