Do I keep this hose?(Ear Shave) - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 04-06-2014, 04:29 PM Thread Starter
HowardLangston's Avatar
Starting removing some things for the ear shave. When I got to the emissions junk I have one hose I'm not sure what to do with. (In the first pic attached) The hose runs down on the right side and goes down near the rear tire. The "goats belly" blocks my view of were it ends. The other picture attached is where the hose was attached to the emissions junk. On the open Part of the plastic T joint.(Black arrow) Just want to know if it is needed and if so what does it get attached to when I put it back together.
Thanks for the help.
HowardLangston is offline
post #2 of 12 (permalink) Old 04-06-2014, 04:35 PM
no you don't keep that hose.. that whole little valve and all the hoses to it get thrown away... just cap off the vacuum ports on the carbs.
post #3 of 12 (permalink) Old 04-06-2014, 04:41 PM Thread Starter
Great thank you. Do you know where the hose ends so I can remove it.
post #4 of 12 (permalink) Old 04-06-2014, 04:46 PM
Cap one port on the right side carb, left side connects to the petcock.
post #5 of 12 (permalink) Old 04-06-2014, 08:37 PM
Unless you have Calif. emiissions (tank) you have no other issues......
Ensure the Tee'ed from both carb's is maintained in (crs for correct/definative terminolgy) idle Air for negative throttle response issues....
post #6 of 12 (permalink) Old 04-07-2014, 06:07 PM Thread Starter
Still kinda confused about what to do with the hose still attached to the bike. Should I cut it short and just leave it or something else?
post #7 of 12 (permalink) Old 04-07-2014, 06:42 PM
Pull it of the carbs
post #8 of 12 (permalink) Old 04-07-2014, 08:28 PM
If we're talking about the vacuum line that ran to the suction valve for the air system.... That line connects to the right carb, but you remove it from the carb and plug the vacuum port on that carb.
post #9 of 12 (permalink) Old 04-07-2014, 10:15 PM
On an ear-shave that (emissions removal) (right carb) vacuum port need's to be plugged.
post #10 of 12 (permalink) Old 04-08-2014, 08:30 AM Thread Starter
Thanks guys that cleared up my confusion. Thanks for all the help.
