Carb tuning problems - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 58 (permalink) Old 04-04-2014, 04:14 PM Thread Starter
Crowley
crowley1027's Avatar
A few problems to list with a little history:
Ear shaved, and custom exhaust with 8" baffles.
Inline filters on the fuel line. Persistent issue I notice is that one filter stays filled with fuel, while the other stays empty (while fuel still passes through it).
I would think maybe there is a float problem? This would play into the next issue:
I upped Jets to 40/140 and had severe pop on deceleration. I've narrowed it to the front cylinder - same cylinder with empty fuel filter.
I pulled carbs and cleaned. One coasting enricher was stuck, so I cleaned, sanded, and confirmed that it moved. Both diaphragms are intact and working well. I upped pilots to 42, turned 2.5 out on both, no change. Turned front cylinder out until pop went away mostly, but I ended up between 3.5 and 4 turns out. Even then, I still got some pretty poppy pop in first gear rolling off the throttle pulling in the driveway.
Like I said, maybe there is a float issue in the front carb? I didn't open the float chambers while cleaning carbs
I didn't make a good user name and I can't change it, so please call me Nate.
crowley1027 is offline
post #2 of 58 (permalink) Old 04-04-2014, 05:04 PM
I am only going to address one thing on this, others will chime in on other issues (as well as this one I am sure)
your filter that stays empty (but fuel flows)... I suspect its got a big air bubble stuck in the filter.. remember, air will rise to the highest point it can (without lots of external forces, such as large volumes/pressures of air, or fuel).
post #3 of 58 (permalink) Old 04-04-2014, 06:23 PM Thread Starter
Crowley
The fuel line is arced upwards, there's a section of hose that's higher than the petcock outlet and the filter... I'll swap the line with another one.
I looked at it after it sat for a bit, and it was half full. After starting the bike it immediately drained
post #4 of 58 (permalink) Old 04-04-2014, 06:45 PM
personally I would scrap the fuel filters until after you have the backfiring fixed.
post #5 of 58 (permalink) Old 04-04-2014, 07:00 PM Thread Starter
Crowley
Will do. There was a nice little inline that came with the bike when I got it, so I'll pop that on. It's a bullet style, not the cheap huge conical one like I have on
post #6 of 58 (permalink) Old 04-05-2014, 03:56 AM
You knows that stock from the factory there aren't any fuel filters.
post #7 of 58 (permalink) Old 04-05-2014, 06:56 AM Thread Starter
Crowley
There's junk in my filters already... If I can fit a filter under there I'm going to lol
post #8 of 58 (permalink) Old 04-05-2014, 02:59 PM Thread Starter
Crowley
Got the popping removed, I can Rev high and let the throttle go and it cruised nice. It still pops on low revs but not overly concerning.
post #9 of 58 (permalink) Old 04-05-2014, 03:10 PM
good deal.. and flat spot gone too?
post #10 of 58 (permalink) Old 04-05-2014, 03:20 PM Thread Starter
Crowley
No, flat spot still there. I would describe it as a power hesitation. I need bigger mains, since it cuts out pretty bad around 5500 under heavy throttle... Wonder if that'll help.
Since I'm 3.5 turns out on one carb, do you think I should up from 42 to 44 or 45,whichever is next up?
