cant open fuel cap - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 08-11-2007, 01:15 AM Thread Starter
cant open fuel cap
Try as I might I cant get the gas cap open. Just got this bike as a basket case and working on getting it together and running but i cant get the damn cap to open. Using key that works on locks and ign. Put in in and turn clockwise while pushing cap down. It turns about 1/8-1/4 turn and thats it. Tried graphite first then liq. wrench but the wench wont open. Grrrrr. Hep me Hep me
newvn750owner is offline
post #2 of 12 (permalink) Old 08-11-2007, 01:32 AM
BMan23777's Avatar
The key on my cap only turns a 1/4 turn to open.When you have it turned have you tried to pull up on it at all?
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #3 of 12 (permalink) Old 08-11-2007, 02:48 AM Thread Starter
Yeah I have tried it. Pull up after cap is pressed down while turning key. Its almost like locking tab isnt releasing. It feels like key cyl is working as it should but it will not open.
post #4 of 12 (permalink) Old 08-11-2007, 08:40 AM
2FAS4U
We have that problem on the 86. Try installing the key only part of the way in and turning. It works for us.
2fas4u is offline
post #5 of 12 (permalink) Old 08-11-2007, 12:12 PM
dirtrack650's Avatar
Here's what I had to do...
I was a good boy and had an extra key made for my 95 and put the original in a safe place. So I went on a ride, needed gas and, as is was, in the middle of nowhere. The new key worked the ignition but not the gas cap.
To shorten the story, I ended up pounding out the hinge pin on the cap and taking it to a key maker to fit the ignition key to the cap. $20 but worth it. Use a flat punch or you will bugger up the hinge pin getting it out.
dirtrack650 is offline
post #6 of 12 (permalink) Old 08-13-2007, 01:32 AM
Loran in Npvl IL's Avatar
try pushing down on the gas cap (and holding it down) as you turn the key. This will remove some of the presure off of the lock.
Deuce (Loran Naperville IL)
2003 VN750
- Corbin seat w backrest
- Progressive suspension.
- Kury iso goldwing grips
2 1983 V65 Magnas
Loran in Npvl IL is offline
post #7 of 12 (permalink) Old 08-13-2007, 02:24 AM Thread Starter
yeah I have tried all of the above. going to take it off the hinge and see what gives with it. its always the smallest damn things that give the most trouble
post #8 of 12 (permalink) Old 08-13-2007, 02:55 AM
I'd guess that it's not the same key for the other parts as the gas cap.
Did ya only get the one key for it??
If ya can get it off at the hinge, a locksmith should be able to re-key the lock.
post #9 of 12 (permalink) Old 08-13-2007, 11:31 PM Thread Starter
yeah it just came with the one key. it works on everything but the gas cap. the strange thing is that it goes in and turns the lock but will not open
post #10 of 12 (permalink) Old 08-14-2007, 05:14 AM
That is strange. Something must have got disconnected in the lock then.
Good luck with it. Maybe it'll be an easy fix
