Carb hose problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 03-26-2014, 07:50 PM Thread Starter
HowardLangston's Avatar
Carb hose problem
I was looking over the bike today and found that one of the hoses on the carb had a hole in it. It had been resting against the engine and melted a small hole. I have had problems with the bike running smoothly and this may be one of the issues. I have two questions. Is the hose in the correct spot? To me it does not seem correct. What type of hose should I use to replace it? The hole is where the electrical tape is in the attached pictures.
HowardLangston is offline
post #2 of 5 (permalink) Old 03-26-2014, 08:15 PM
That appears to be your Vacuum Line for your Emissions on the right carb vacuum port.
Yeah, a vacuum leak will cause issues running well/smoothly.
Replace with Vacuum Line or remove Emissions junk and cap/block the carb vacuum port off.
hth
post #3 of 5 (permalink) Old 03-26-2014, 08:25 PM
Also....your carb should have a 90 deg bend off of it...you come straight off...thats what is putting you fuel line too close to heat....I suggest you get a brass 90 deg CVK Hi-Flow fitting for both carbs....your bike will love you, and you will again love your bike....
http://www.johnscycleparts.com/store...&product_id=55
You can get em for less at any custom Harley shop....
post #4 of 5 (permalink) Old 03-26-2014, 08:57 PM Thread Starter
Thanks for the help guys. I am doing the ear shave next week when all the parts get in. Is there a certain brand/type of hose I should use to replace that one?
post #5 of 5 (permalink) Old 03-26-2014, 09:07 PM
Just regular vacuum hose, need it long enough to reach the valve in front of the battery. But since you're shaving, it's a perfect time to lose all those emissions hoses too, just need coasters or cap off the reed boxes.
That vacuum port gets capped off if you coaster/cap.
