Carb Vent Caps? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 03-24-2014, 12:17 PM Thread Starter
Jerrywest22's Avatar
Carb Vent Caps?
I am doing the earshave now and I am confused on capping the carbs. It states in the procedure to cap the right side carb vacum port but it does not say to cap the left.
The left side vent runs into the center nipple on the petcock. Why cant i remove that hose and also cap that vent?
Jerrywest22 is offline
post #2 of 9 (permalink) Old 03-24-2014, 12:21 PM
The petcock is vacuum controlled.no vacuum no fuel no fun
post #3 of 9 (permalink) Old 03-24-2014, 12:29 PM Thread Starter
apreciate the reply. it just seems weird that you can cap the one on the right side.
post #4 of 9 (permalink) Old 03-24-2014, 12:32 PM
If I remember correctly the one you cap off goes to the pollution crap you take off when ya earshave.
post #5 of 9 (permalink) Old 03-24-2014, 01:01 PM
The left carb vacuum goes to vacuum controlled petcock.
Yes, you have it 100% correct ODD.
post #6 of 9 (permalink) Old 03-24-2014, 06:39 PM
Just fer haa haas, I tried joining the 2 vac lines to a tee, then going to the petcock ( I assumed more suction....wrong)....seems the volume of the lines reduces the actuating effect on the petcock....do it as described, and you'll be ok.....
post #7 of 9 (permalink) Old 03-25-2014, 03:36 AM
Alpha Geek
Hexadecimus's Avatar
That makes sense about diminishing the vacuum with them connected...
Some people permanently plug the right vent with screws or whatever, but I'm wary of permanent modification. If you don't want to bother buying a vac cap (for me out in the sticks that's about an hour drive IF anyone has stuff in stock), I cut about 1/2" of vac line and plugged the end with super black RTV. Free and works just as well.
Hexadecimus is offline
post #8 of 9 (permalink) Old 03-26-2014, 07:32 PM
Pretty much what I did with mine after....1" piece of hose, RTV and a sheet metal screw....
post #9 of 9 (permalink) Old 03-27-2014, 03:17 PM
I wouldn't have expected that.
I know a while back someone had a noisy petcock...a tapping noise. they connected both vacuum lines to a "T" and into the petcock control and it evened out the pulses of vacuum, which in turn stopped the tapping noise.
