Cleaning carbs/ear shaving Questions - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 03-23-2014, 12:50 PM Thread Starter
HowardLangston's Avatar
I picked up a used 2006 last week. Since I have had it has had a hard time idling with no choke. The engine also seems to be hesitating below 4500 RPM. Doing some research on the site and getting some advice I am going to clean the Carbs and do the ear shave. I just had a few questions to make sure I have the right parts. I need to replace one of the float bowl drain screws(it is stripped) Is this the correct replacement part.
siriusconinc.com/pro-detail.php?pid=&product_id=120520
Also when doing the ear shave are these what I use to cap off the vacuum lines?
siriusconinc.com/pro-detail.php?pid=&product_id=3978
Thanks in advance for any help.
HowardLangston is offline
post #2 of 3 (permalink) Old 03-23-2014, 03:00 PM
Not sure if this link will be helpful, but it is very clear (best I've seen) in VN750 Carb Pulling & Ear Shaving Procedure (with suggested part info).
http://06vn750.blogspot.com/2011/05/...nt-format.html
hth
post #3 of 3 (permalink) Old 03-23-2014, 03:56 PM Thread Starter
It did help. I used that to order the parts needed. Can't wait to get started. Thanks.
