Can't get carb out? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 03-22-2014, 03:48 PM Thread Starter
Can't get carb out?
I bought a '92 750 a few months ago, in the dead of winter. I knew she needed some work and it's finally warm enough to start...well mostly. In any case, I've got some mechanical experience working on cars through the years (engine swap, trans replacement, misc parts all over the place), but motorcycles and carburetor engines are new territory. Unfortunately, I'm having trouble with the most basic of things..I can't get the damn thing out!
I've disconnected the air intake hoses, the throttle cables, fuel lines, removed the fuel tank, etc.. The problem is the carb seems to be pretty stuck in there. The carb itself is disconnected from the cylinder on each side, with the hoses still attached to the cylinders. The air intake hosts are also disconnected from the carb, but still attached to the plastic air intake manifold. I tried pulling those out, but I'm afraid of tearing the hoses at this point.
I also can't get the choke cable disconnected - but I've got enough slack that I can probably take care of that once it's out - definitely a tight fit in there.
Any advice on getting the carb out? I can't find any decent videos on youtube - just before and after which doesn't do much good.
kagaku is offline
post #2 of 19 (permalink) Old 03-22-2014, 06:57 PM
If I remember right, it comes out easiest to the right side....its not easy by any means, but once you do it once, it will seem easy....helps to have the big plastic airbox removed....but then ya do an earshave, which Id say over 1/2 here have done....
post #3 of 19 (permalink) Old 03-22-2014, 09:21 PM
Yep right side
post #4 of 19 (permalink) Old 03-22-2014, 09:41 PM
Mountain Man
Spots's Avatar
Its probabky hanging on the intake boots. Leave the left boot (front cylinder) on the motor and pull the carb out from it. Leave the right boot (rear cylinder) on the carb and remove it from the motor. Its a real pain, much easier with the airbox gone but then you gotta rejet and buy pod filters. Ive had mine on and off 5 times this week.
"You cannot exaggerate about the Marines. They are convinced to the point of arrogance, that they are the most ferocious fighters on earth- and the amusing thing about it is that they are."
1993 VN 750 bobber/bagger mix named "Halfbreed"
Degoated
Turn signals deleted
Center stand deleted
Custom wrapped straight pipes
Ear Shave
NGK Iridium plugs
Mean Streak seat
MCCT conversion
Saddleman saddlebags
Spots is offline
post #5 of 19 (permalink) Old 03-23-2014, 01:51 AM
Chasin' the blacktop
Spencer1's Avatar
X2 but a few additional thoughts. The choke cable is probably the one cable you need to get off to get the carbs out. The throttle cables are long enough to allow the carbs to pull out past the bike a few inches..
Using a long screwdriver or thin prybar wedge the black plastic surge tank (air box) up high, really get 'er up there a few inches. then pull the carbs off the boots and then work it out the right side.
Takes a while the 1st time. Patience and figure about an hour to get the carbs out the 1st time. Remember that they are expensive thin aluminum so no kicking. Grab a beer and work slowly.
After pulling my carbs and realizing they were going to be just as hard to get past the surge tank and back in I went ahead and did an earshave just so I could pull that darn surge tank.
North Georgia
Spencer1 is offline
post #6 of 19 (permalink) Old 03-23-2014, 08:06 AM
Mountain Man
Spots's Avatar
I missed the comment about the choke cable the first time. You are right, I don't think there is anywhere near enough slack to pull the carbs with the cable attached. And after fighting with that bastard of an airbox getting them out I was kinda gleeful when I cut it in pieces to earshave the bike lol
Degoated
Ear Shave
NGK Iridium plugs
Mean Streak seat
MCCT conversion
Spots is offline
post #7 of 19 (permalink) Old 03-23-2014, 11:39 AM
Detailed instructions here
VoIPDoc is offline
post #8 of 19 (permalink) Old 03-23-2014, 03:46 PM
There ya go....
post #9 of 19 (permalink) Old 03-24-2014, 12:13 AM
Alpha Geek
Hexadecimus's Avatar
Totally worth the "ear shave" in my opinion if you ever work on your own bike. It's hard enough with the air box out. And you don't necessarily need to rejet. My bikes dropped from 50 mpg to 42 with a rejet so I think I can drop a size and tweak my idle screws instead.
Hexadecimus is offline
post #10 of 19 (permalink) Old 03-24-2014, 12:18 AM Thread Starter
Thanks for the great advice everyone, I think I'm going to give the ear shave procedure a shot. The unfortunate thing is buying the parts will take a few weeks, but it definitely seems worth it to me.
kagaku is offline
