After market carbs. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 03-16-2014, 06:24 AM Thread Starter
Big Nick's Avatar
After market carbs.
I was just thumbing through Ebay looking for jets, when I noticed pairs of Mikuni carbs for Snow mobiles. I think in a pinch they could be quite the mod for a VN 750. One pair of a Skido, and another of an ex 700. The Skidoo came with the forked throttle cable at a glance, maybe $100 the pair used.
Just a thought.
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #2 of 2 (permalink) Old 03-18-2014, 12:39 AM
In my own opinion, and in the opinion of several others that are in the knowing, Mikuni would be the way to go....theyre simple and they perform....theyre also easy to work on and parts are everywhere....
So, youre considering 2 Kunis then w/o a single manifold....Ive considered doing that.....you just need to fab a bracket to anchor the split throttle cable....and a stabilizing bracket for the carbs themselves...thats it....
If yer gonna do it, do what I did....either change the petcock out to a single outlet, or join the 2 fuel tines with a tee, then split em again....your guaranteed even flow to each then....the present setup doesnt allow that if one outlet gets blocked.
