carburetor mix screws - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 83 (permalink) Old 03-14-2014, 07:45 PM Thread Starter
jcryan1988's Avatar
Hello how's it going? I have a 1999 Kawasaki Vulcan 750 with 3,000 miles on it. When I got it it wouldn't run correctly, before I found out the carbs were gummed up I messed with the adjustment screws and the black air screw. I brought it to a friend of mine that got the bike running good, but when I ride it around the yard and i come to an incline and stop and try to take off again the bike will stall out and when I roll it to flat ground and take off again it is fine. Could my lack of power starting off on an incline be because the screws aren't in the correct position? Not sure if it makes a difference or not but I am practicing in my back yard in the lawn. I want to make sure this bike is in tip top shape before I get it registered. I was told I should bring it to a shop to find out if the adjustment screws are in the correct position but money is pretty tight right now for me to be able to afford a shop. Is there a way to figure this stuff out myself? Thanks!
jcryan1988 is offline
post #2 of 83 (permalink) Old 03-14-2014, 08:07 PM
No need to pay a shop, many experts on the forum can/will inform (in detail) you how to do it yourself.
I am not one of them. Be patient for a day or two.
post #3 of 83 (permalink) Old 03-14-2014, 08:14 PM
Crowley
crowley1027's Avatar
You should go into the carbs section of this forum and view the sticky that labels the Carburetor parts.
The external adjustable parts are the idle adjuster and air/fuel mixture screw. You can easily identify these through the sticky I mentioned.
I suspect you fiddled with the idle adjuster, the black knob. That only adjusts idle, as far as I know... So start your bike, let it warm up (I think), make sure choke is off, and turn the back knob till idle is 1000 rpm.
The air mix screws may be your problem. Get a long thin screwdriver (I just picked a set up at harbor freight for 4 dollars. Again, refer to some diagram to show you where the adjust screws are located. They are at a strange angle... Turn them all the way in, and turn them out two and a half turns.
crowley1027 is offline
post #4 of 83 (permalink) Old 03-14-2014, 08:15 PM
Crowley
I also suspect another problem. You aren't getting the power you need when it dies... It could be a bunch of problems.
post #5 of 83 (permalink) Old 03-14-2014, 08:29 PM
very correctly stated.
With engine not running, Adjust (fine tune) for highest idle...that'll get you VERY close.
Start engine, then fine tune if/as necessary.
Many notes in forum verses...& probly a sticky.
post #6 of 83 (permalink) Old 03-14-2014, 08:31 PM
Crowley
I'd say clean the carbs... It's not fun, for me it was scary, but I did it and got it all back together and working....... Have a friend that knows what they are doing perform this.
Try to search for Wolfie's "carb blowback"
post #7 of 83 (permalink) Old 03-14-2014, 08:39 PM
Crowley
Are you sure you aren't the problem? I don't want to sound offensive, but is it possible you aren't giving it enough gas or pulling the clutch out too fast?
post #8 of 83 (permalink) Old 03-14-2014, 08:44 PM
The description makes me think it could be the sidestand switch.
post #9 of 83 (permalink) Old 03-14-2014, 08:50 PM
Crowley
Good idea
post #10 of 83 (permalink) Old 03-14-2014, 08:56 PM Thread Starter
jcryan1988's Avatar
It currently idles a little under 1,000 rpm. I fixed a buddies computer and in return he cleaned the carbs and bought a couple new parts for them when he cleaned them for me. I wish I left the adjustment screws alone and the idle adjuster alone when i got the bike and just waited for him but i was anxious to try to get it going and became a "google warrior" and found a forum NOTHING like this one where someone had the problems I was having and someone suggested messing with adjustments. I do know exactly where the screws on the carbs are and yes they are on an angle, I got the perfect screwdriver for them. I will go into the carbs section and read up like you said. Should I turn the screws all the way in and bring them out 2 and a half times first? Or should I start the bike and adjust the black air adjustment screw until it idles at 1,000 rpm first? Thanks a lot for your responses!
