Just a comment or reserve capacity - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 03-07-2014, 11:21 PM Thread Starter
I did search old post for this topic, and did not find one. I refuel at 100 mile max. Because I ride the mountains and secondary roads. I did have to switch to reserve today, 1/4 mile from gas station. I have read our reserve is .6 gal. When I refueled from just on reserve, 2.74 gal. I allways fill to the same point, 1/8" above bottom of fill neck sitting on bike level. So, 3.6 gal total - 2.74 gal would mean reserve = .86 gal. give or take some. So @ 50 mpg, hopefully a station is closer then 43 miles. I was wondering how far up the fill neck is 3.6 gal?
smltownr is offline
post #2 of 13 (permalink) Old 03-08-2014, 07:13 AM
2FAS4U
I would agree that 140 miles is about the limit, depending on riding conditions.
I don't take it that far.
2fas4u is offline
post #3 of 13 (permalink) Old 03-08-2014, 08:56 AM
my last long ride I managed to need reserve.. used it for about 5 miles.. filled to the about the same as you (just short of filler neck). was still under 3 gallons.
I am guessing at this time the figures for size of the reserve are off?
michiganteddybear is offline
post #4 of 13 (permalink) Old 03-08-2014, 01:37 PM
i have pushed the reserve for about 25 easy riding miles but i dont recommend it and i only get around 35 to 40 mpg due to my jets being 142.5 mikuni mains and 42 keihin pilots
with extremely free flowing k&n drop ins on a modified air box and vance and hines pipes
post #5 of 13 (permalink) Old 03-08-2014, 05:34 PM Thread Starter
NR Yup @ 35-40 mpg .86 gal would be 30-34 miles. 25 miles is cutting it close especially if in non familiar territory
smltownr is offline
post #6 of 13 (permalink) Old 03-08-2014, 07:18 PM
Chasin' the blacktop
Spencer1's Avatar
I hit reserve 2.7 gal down, I've ridden reserve an additional 30 miles in an area I know well just to test it, guess I was in a testing mood that day.
North Georgia
Spencer1 is offline
post #7 of 13 (permalink) Old 03-09-2014, 01:11 AM
Years ago I did similar......carried a qt. of gasoline just in case. LOL
I found book spec's to be close to correct.
post #8 of 13 (permalink) Old 03-09-2014, 09:17 AM
Deviate's Avatar
When I first started riding and my bike was still stock I went over 150 miles on a tank. But I was babying it. Typically now, I have to switch to reserve at about 130-135. I do fill mine up the neck though if I know I'm going to be riding for 10 miles or more before I park it. If you fill it up the neck too much and then put it on the side stand, gas will overflow out of the vent tube.
Leave it to me to NOT be fond of something then end up banging it.
Deviate is offline
post #9 of 13 (permalink) Old 03-09-2014, 10:02 AM
'03 VN750 "Rosie"
bstew7890's Avatar
I once switched to reserve thinking I should have about 20 miles left. I made it to work, but on the way home it died again after a few blocks. That was 11 miles. About 9 of those were on the freeway going 70-75. Now when I hit deserve I slow to 60.
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
post #10 of 13 (permalink) Old 03-09-2014, 01:40 PM
When I lived in New York, I had a 30 mile commute to work. If I forgot to fill up after a couple of days of riding, I would switch to reserv about 6 miles from work, ride all over post (probably another 5 or six miles total) and still have enough gas to make it 30 miles to the gas station by my house where the engine would die at the first pump.
