Dumb Reed Vavle Question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-10-2007, 10:24 PM Thread Starter
KENNETH FORTUNE's Avatar
I know this sounds funny but I don't know if I'm looking at the right spot. I see a hose that comes to eah side of the head. And this connection bolts to the side of each head with 2 bolts. Is this where I want to take the hose off and install the marble. Also if I wanted to make a plate is it just a matter of taking a piece of metal and cutting it to fit or is their something speacil about it.
KEN ROD
1998 VN 750
VROC #26481
WILLIE AND MAX SLANT BRAIDED BAGS
R/R RELOCATED, WINDSHIELD
PAINTED RINGS AROUND GAUGES FLAT BLACK
NEW FRT TIRE DUNLOP 110/90 (4/07)
NEW REAR TIRE DUNLOP 170/80 (9/07)
VOLT METER (Knauck69 style)
NEW KEVLAR CLUTCH 2/08
Highway Pegs (Woodydh style)
Custom Cover for rear trunk hole
19082 MILES 2/08
bought bike 11,000 7/25/2006
KENNETH FORTUNE is offline
post #2 of 4 (permalink) Old 07-10-2007, 11:12 PM
BMan23777's Avatar
YOUR IN THE RITE SPOT!!!!I just made coasters for mine and used 1/4" Aluminium and bought shorter bolts and was able to re-use the gaskets.
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #3 of 4 (permalink) Old 07-11-2007, 10:30 AM Thread Starter
Did you remove the hoses or did ou cap them off.
KEN ROD
1998 VN 750
VROC #26481
19082 MILES 2/08
post #4 of 4 (permalink) Old 07-11-2007, 10:33 AM
BMan23777's Avatar
I removed the hoses and the valve under the seat.
Brian Manchester
'89 "GRIMM"
04 durango AWD
