I hear a sucking sound coming from my air cut off valve. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 02-10-2014, 08:14 AM Thread Starter
Question I hear a sucking sound coming from my air cut off valve.
It is a 1994 vulcan 750.Hello I am new to the forum but I am not new to vn750's. It seem my bike was sitting for about 4 weeks and I fire it up runs good for about 10 miles then, at a redlight, I hear a sucking noise {like the kn filter on my truck,I do have kn filters on the bike to but not where noise is coming from}, It is coming from the right side carb air cut off valve and when I cram my finger in next to the circular metal outside of the air cut off valve on the side of the carb it reduces the sucking of air. Now I am sure it is the rubber on the air cut off valve just in bad shape it has wrinkles in it when I looked at it. I do understand to much air mean backfires and high revs also slow rev downs I have all of these. I guess I am just double checking to see if anyone has had a similar problem I was thinking maybe a charging problem but I also have a new gell battery and i t charges to 14.2 at 3500 rpms it is in range. One more thing I did the headlight trick to make it come on always by swithching the blue wire into the open connector and it did make the headlight come on but it wouldnt charge at all just drain the battery it was 12.3 at 3500 rpm changes the wire back to orginal spot now it charges and headlight works is there something wrong there. I would love the advice from the real vulcan mechanics aka you guys thanks alot in advance.
turkeysandwich is offline
post #2 of 7 (permalink) Old 02-10-2014, 01:15 PM Thread Starter
MKay it was the air cut off valves tiny oring not installed correctly. I took it out went to autozone fount one {oring} and voila no more sputters or troubles. Thanks for the help cough cough
post #3 of 7 (permalink) Old 02-10-2014, 01:58 PM
Did you check the O ring in the air cut off valve?
post #4 of 7 (permalink) Old 02-10-2014, 03:06 PM
had that problem on mine (on front carb, left side of bike) after a cleaning. turns out the oring was ok, just not seated...
NOTE: that oring is not normal.. it has a flat side on it that goes against the carb body when installing
post #5 of 7 (permalink) Old 02-10-2014, 03:08 PM
Where is the air cut off valve please. Mine makes a chugging sucking sound at the left K&N filter
post #6 of 7 (permalink) Old 02-10-2014, 05:18 PM Thread Starter
It is the circular looking piece on the side of your carb. It has 2 screws and it pops rite out watch out for that spring or you will chase it across your shop. My oring ironicaly was put on by me of course the wrong side down there is a flat side to it I notice now. They sell flat side/round side o-rings at most autoparts stores just trial and error finding one be sure to get the gas resistant rubber type oring if you do this. It was a easy fix if you have the same problem.
post #7 of 7 (permalink) Old 02-10-2014, 09:10 PM
Search On Line, I've seen them for $40+ and _had_ a link for $24.00+ each....someone w/more info should chime in here soon......
...one EACH carb btw.....
examine/inspect the gasket as well.....
