cvk34 size.. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 02-05-2014, 01:37 AM Thread Starter
Kwakka Dave
evo666's Avatar
cvk34 size..
Hi guys new here, I need to fit a restrictor in my carb (stupid law) but to get one made I need to know the outer diameter of the carb where it fits into the inlet rubber which is bolted to the engine. Also does anyone else get an electric shock off the ht lead on the left?
evo666 is offline
post #2 of 19 (permalink) Old 02-05-2014, 07:32 AM
Where do live that has such a law and why would you grab the plug wire when the bikes running?
post #3 of 19 (permalink) Old 02-05-2014, 08:17 AM
Welcome to the family
post #4 of 19 (permalink) Old 02-05-2014, 08:45 AM
Dr. Vulcanstein
jadabull's Avatar
I pull my leads while the bike is running to test my cylinders, don't know if thats the correct way, but I don't get shocked.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #5 of 19 (permalink) Old 02-05-2014, 08:55 AM
You shouldn't get shocked unless there is a break in the insulation or you're standing barefoot in a puddle of water.
There was a discussion on this awhile back, majority seemed to say not a good idea to pull plug wire while engine running.... But no clear cut issues found if you do.
He must be from France....they only allow slow bikes there...
post #6 of 19 (permalink) Old 02-05-2014, 09:44 AM
Dr. Vulcanstein
jadabull's Avatar
Evolution mark of the beast (evo666). as knifemaker said if you can tell us where your from it will help determine your laws, and what exactly needs to be done.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #7 of 19 (permalink) Old 02-05-2014, 01:19 PM Thread Starter
Kwakka Dave
evo666's Avatar
In the UK. So need to have the bike restricted to 35kw gonna use a washer in the inlet that is why i need to know the diameter. Also i am not pulling the plug, t hat's asking for trouble, it just catches my leg i was wondering if it was aanyone else had experienced it.
evo666 is offline
post #8 of 19 (permalink) Old 02-05-2014, 01:41 PM
Suggest new Spark Plug wires / caps.
Plug Wires: Dennis Kirk has 7mm wire for $2.99 in a 72" length the part # is 20- 21.
Ad two NGK end caps part # 20-306 @ $3.30 and two end caps part # 20- 789 $2.40 each.
(Requires approx.. 60”) Spark Plug Wire Replacement:
2 x 11.5" long
1 x 14.5" long
1 x 20.0" long
You should consider buying NGK plug ends if you haven't already. They are great looking and my directions are based on using them.
Dennis Kirk: [email protected] or 1-800-328-9280
post #9 of 19 (permalink) Old 02-05-2014, 01:41 PM
Never heard of such a thing. If the bikes illegal how it get into the country?
Or, are you altering it for some kind of tax reason?
If the plug wire is shocking your leg you might want to replace the wires and caps....and make sure all spark plugs are gapped right. The right wire has been known to spark against the cylinder head, but not sure how you'd get shocked if your not grounded.
As for the diameter of the carb, can't you just measure it?
post #10 of 19 (permalink) Old 02-05-2014, 01:43 PM
Welcome!
we have a couple of UK members, I am sure one or more will chime in to help you out.
michiganteddybear is offline
Tags
carb , cvk34 , diameter , inlet , size
