carb rebuild kit? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 07-06-2007, 01:36 PM Thread Starter
rider
global_recon's Avatar
carb rebuild kit?
i'm planning to disassemble the carbs and give them a thorough cleaning. has anyone come across a rebuild kit which would provide replacement o-rings/gaskets/diaphrams/etc or do i have to buy all that stuff separately? i've checked out the microfiche at ronayers.com... just not really sure all the stuff i should buy. ron ayers takes a while to ship things... i'd prefer to have all the necessary parts before i start ripping these apart. thanks.
paul
1991 vn750: 'for great justice'
http://www.globalrecon.org
follow my rides on twitter: http://www.twitter.com/globalrecon
global_recon is offline
post #2 of 2 (permalink) Old 07-10-2007, 01:26 AM
asaracho's Avatar
I just took my carbs apart and the only parts that I needed were the air cut-off valves or coasting enricher (which you can check with the carbs on the bike) and float bowl gaskets. Everything else was fine. I don't think there's kits for our carburetors but I think it helps to have access to a hardware store that sells o-rings in case you do need a few of those smaller, popular size, o-rings.
1989 VN750
- 31,XXX mi.
Denver, CO
asaracho is offline
