Repro air filter elements. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 01-22-2014, 06:10 AM Thread Starter
Big Nick's Avatar
I removed my stock air filters to find the foam had completely disintegrated.
Not an uncommon problem with age, so down to the local rubber and foam merchant I went, invested $5. Then stencilled around the gauze elements, used a little glue,and hey presto, new foam filters.
A quick spray with the correct oil, and ready to install.
I love it when a plan comes together!
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #2 of 3 (permalink) Old 01-22-2014, 07:12 AM
Good deal. I'm sure you picked up a foam very similar to the density ect of the oem filters.
You might want to mention what glue you used as not all will be foam friendly or automotive tough.
Good job reviving on a budget!
post #3 of 3 (permalink) Old 01-22-2014, 10:46 PM Thread Starter
Big Nick's Avatar
The glue I used was Bostik multi bond. The foam supplier recommended glue they had on the shelf. Fingers crossed,that my glue works, or it's back to the drawing board.
The Lion!
12 inch apes
1986 A3 series 750
170 rear tyre
Solo mod
Six pack rack
Replaced CDI
Coasters
Penrite 10/50
Shows 67000 kms
Big Nick is offline
