Carb Boot Alignment - Part II - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 01-18-2014, 04:30 PM Thread Starter
93VN750's Avatar
So I haven't worked on my 750 for a few years and finally decided it was time to put her back together.
Putting the carbs on is a challenge, especially when you haven't touched them for years.
I know my problem is the boot alignment. Mine are worn so I have no idea where the alignment spot on the boot is to reference against the cylinder protrusion (which I know location of).
Anyone have a way to describe how the boots are oriented without the benefit of the tab on the boots?
Help is of course greatly appreciated!!
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #2 of 3 (permalink) Old 01-18-2014, 06:23 PM
Far as I can remember, the triangle was right at the seam, so ya got a 50/50 chance....but if you look at the carb to head flange alignment, you should get it...I think the both faced inward a little...been a few years....
post #3 of 3 (permalink) Old 01-18-2014, 11:25 PM
trial and error is how i did it then i decided the next time i took them off to leave one boot on the carbs and one on the head so as to not mess with the alignment
