Mixture screw initial settings? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 01-18-2014, 03:22 PM Thread Starter
What is the consensus on the mixture screw initial setting? 2 turns out?
Overkill is offline
post #2 of 17 (permalink) Old 01-18-2014, 03:38 PM
I run mine 2 turns out. My bike is stock and that is rich. I like good 'manners'.
Idle is idle. No amount of external modification will change the amount of air/fuel necessary to idle. It would be a discussion I would probably enjoy.
wmsonta is offline
post #3 of 17 (permalink) Old 01-18-2014, 03:45 PM
I ran pods, degoated with screaming eagle muffs,140/40 on jets and about 2.5 turns out
post #4 of 17 (permalink) Old 01-18-2014, 03:51 PM
Never got the caps off mine.
post #5 of 17 (permalink) Old 01-18-2014, 04:01 PM
Get a very small drill bit or a punch.get a hole in there and pop it out
post #6 of 17 (permalink) Old 01-18-2014, 04:06 PM
Probably tickled with it aren't you, Spock?
Mine will chug right along in 2nd gear on level ground with no throttle. Common sense should tell that is more gas than it takes to idle in neutral.
wmsonta is offline
post #7 of 17 (permalink) Old 01-18-2014, 10:51 PM
Chasin' the blacktop
Spencer1's Avatar
They come from the factory 1 5/8 turns out to pass EPA requirements.. General consensus here is 2 1/2 turns makes it about right if things are stock.
North Georgia
Spencer1 is offline
post #8 of 17 (permalink) Old 01-19-2014, 03:15 AM Thread Starter
Thank you so much! This is a great place with many knowledgeable people!
Overkill is offline
post #9 of 17 (permalink) Old 02-14-2014, 05:01 AM
Big Nick's Avatar
Mixture screws?
So I presume the further out the mixture screws go, the more fuel introduced to the mixture equation? Mine are set 3 turns out on the front and 3 and a half on the rear. Stock air filters, and quite open mufflers on the original collector. It cracks back through the pipes on deceleration so I'm thinking of uping the jets to Docs 140/40 size,it may help save my bike from leaning out. Any thoughts on this fellows.
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #10 of 17 (permalink) Old 02-14-2014, 06:16 AM
Shouldn't need to up the jets with stock filters.are you coastered or marbled? If not read up on it in the verses.these bikes backfired a lot stock
