Idle Adjustment Screw/Cable - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 01-16-2014, 07:14 PM Thread Starter
Lucky me! I'd always had a problem with my bike's idle, and could never really seem to pin it down because my idle adjust didn't work. Turns out one of the previous owners backed out the damn thing so far it tore the cable apart...
Where can I pick one of these sweet babies up?
Brickstack is offline
post #2 of 9 (permalink) Old 01-16-2014, 07:21 PM
romeobravo172
romeobravo172's Avatar
You might find a used one here, or MA KAWI has them for about $80 !!! You also can find a small threaded screw and use that, although changing the adjustment would be a little harder.
If it ain't broke I ain't gonna fix it!!!
romeobravo172 is offline
post #3 of 9 (permalink) Old 01-16-2014, 07:24 PM
....check Ebay....and put a querry in sell/swap....just fyi, a Harley aftermarket for a CVK should work....
post #4 of 9 (permalink) Old 01-16-2014, 07:26 PM Thread Starter
I'll be damned. Poor students like me don't have that kinda money! Thanks for the input though. I can't believe they managed to do that though. You'd think they felt it tearing the metal cabling inside the casing apart, but... I guess not.
post #5 of 9 (permalink) Old 01-16-2014, 08:12 PM
An old school fix.....cut out the frayed parts, lube it up with bearing grease or white lithium.....should last awhile, because once its set, you dont mess with it much.....
post #6 of 9 (permalink) Old 01-17-2014, 02:17 AM
Another Ol' Schol fix, use a throttle cable, and solder a screw end into it, iirc there used to be wire thumb screw conversion for old Rochester carbs so you could dial in the air fuel mixtures with out any tools on the race track.
post #7 of 9 (permalink) Old 03-28-2014, 01:19 AM Thread Starter
Hey there guys, small update: I found a replacement for the idle adjustment cable. Only problem is, I don't know how I'm gonna make this sucker fit in that housing the thumbscrew sits in. Any ideas?
post #8 of 9 (permalink) Old 03-28-2014, 01:40 AM
The black knob, should be removable.....I never looked close at it, but....
1) check for a setscrew in the side of the plastic
2) grab the end closest to the knob with needlenose vise grips, and try to unscrew the knob.
3) check the top of the plastic knob for a plug...remove it...could be a screw head under to remove it from the cable....
....ie....these knobs were installed once....means that they can be uninstalled.....
....if none of that works....take the bracket off the old, and cut 2 slots in it with like a thin dremel blade....bend the cut in oposite directions....install the new cable...bend the tabs back to lock....
Without actually seein it, its difficult to give ya just one answer...sorry man....
post #9 of 9 (permalink) Old 07-02-2014, 10:00 PM
Where did you find it?
dave_jackson is offline
