Air Filters...bike running rich? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 01-06-2014, 06:22 PM Thread Starter
Noob here, been on my 750 for a couple months now, had a 500 before.
So, I replaced the air filters on the bike, the ones that were in there when I bought it were in terrible shape. Ever since the bike has been incredibly hard to start, sometimes not even turning over until it eventually loudly pops and gets started. Also, mileage has been bad since, and it will sometimes lose rpms until it stalls at stoplights. I suspect the air filters because it only started then, but I'm not sure. Could I have clogged them with too much oil, would that make that much of a difference? Or could my problem be electrical?
Thanks for your opinions!
jguz is offline
post #2 of 17 (permalink) Old 01-06-2014, 06:54 PM
R/R = Relocated Redneck
Jakzen's Avatar
Welcome to the chaos. How did it run before you put the new filters in? If it ran well, if try pulling the filters and clean them. If you're going to oil them, do so lightly.
Mods
Voltmeter/clock/temperature gauge
HD Electra Glide Fairing
Earshave/Coastered/CA emissions - gone...
Nightster seat
Tombstone taillight
Drag specialties turn signals relocated
Sportster progressive shocks... Dropped rear 1 1/2"
Progressive Fork Springs dropped front 1"
NGK plug wires and iridium plugs
Coil Relay Mod
Paint
ACCT to MCCT
Honda Rebel luggage rack
VN800 Handlebars & controls
Screamin Eagle mufflers
F&S Engine Guard & Kury highway pegs
Jakzen is offline
post #3 of 17 (permalink) Old 01-06-2014, 07:48 PM
Welcome to the family.get an agm battery.that'll make starting easier.when it stalls out is it running on one cylinder? The float needle could be dirty and not closing all the way, causing it to flood
post #4 of 17 (permalink) Old 01-06-2014, 07:50 PM
I personally never liked oiled filters....I like the washable new type media. Oiled filters dates back to the 20's, lol....
Try removing the filters and take a short ride....some aftermarket elements are way too restrictive....if runnin w/o the filters helps, wash the oil out and try runnin em dry...
post #5 of 17 (permalink) Old 01-07-2014, 02:25 PM
If it still runs poorly with the filers cleaned, I would suspect that a piece of foam from the old filers made it's way into the carbs and could be causing the problem.
post #6 of 17 (permalink) Old 01-07-2014, 02:45 PM
thats what i was thinking or else the previous owner richened the fuel mix because the old filters were lettin in too much air
post #7 of 17 (permalink) Old 01-07-2014, 05:36 PM Thread Starter
Thanks guys! Still running poorly after a second clean. Might have to clean the carbs, but I'm going to try to rule out any electrical first.
jguz is offline
post #8 of 17 (permalink) Old 01-07-2014, 08:40 PM
just remember if it looks....walks.......quacks like a duck its a duck you stated the problem started after the new filters
what did the old filters look like
post #9 of 17 (permalink) Old 01-07-2014, 09:21 PM Thread Starter
Pretty dirty and bad...parts of the filter were missing on both sides, foam just hanging around in pieces.
jguz is offline
post #10 of 17 (permalink) Old 01-07-2014, 09:25 PM
take it from me i have delt with this before first hand the carbs have literally ate the old filters and are now clogged with debris
best bet is to remove the carbs and thoroughly clean them out
the filter baskets are only meant to keep the filters from caving in but once they start to dry rot they will get sucked thru the baskets
Tags
air filter , rich , stall , starting problem
