my turn to pick y'alls brains - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 12-31-2013, 02:46 PM Thread Starter
ok here is the skinny
94 vn750 bone stock less than 4k miles that has been sitting for 7 yrs due to a floppy shifter
i split the cases and replaced the tie rod
engine has no leaks of any sort
carbs have been completely disassembled and dipped in chem dip
all diaphragms look good or are new checked for pin holes with flashlight and magnifying glass
stock jets 132 and 38 totally cleaned
all boots are tight and proper no leaks
floats adjusted to proper levels
air fuel mix is at 2 1/2 turns out
and here is the problem the bike runs awesome on the road with plenty of giddy up and no stumbles on acceleration even at wide open however at idle she stumbles and dies like she is running lean
also she runs better when on full choke
what do you guys think
post #2 of 22 (permalink) Old 12-31-2013, 03:27 PM
Did you do the carbs, NR?
Did you mean 'full' choke and is that at cruise, WFO or idle? How does it run on the pilot circuit above idle? The first 1/4 of throttle.
wmsonta is offline
post #3 of 22 (permalink) Old 12-31-2013, 03:33 PM Thread Starter
i did the carbs myself and surprisingly for them taking a 7 yr nap they were not too bad
the bike runs smoother at idle when fully choked so i am thinking it is running lean but adjusting the air fuel mix does nuthing for it
there are no stumbles at 1500 rpm or higher
all vac lines are new and tight
post #4 of 22 (permalink) Old 12-31-2013, 03:35 PM Thread Starter
on a side note this thing has more acceleration than my bike which has bigger jets a more open intake and v&h pipes go figure
however im sure my bike has lower compression due to many more miles
<this post is totally unrelated to the problem at hand>
post #5 of 22 (permalink) Old 12-31-2013, 04:01 PM
ok, here comes a guess.
Barring the possibility you swapped the main air jet(s) and the pilot air jet(s), it is probably something in the pilot circuit between the first 2 throttle bore orifices. With the throttle closed you will see the first orifice on the floor of the bore. As you open the throttle, the blade will uncover the other 2 or 3 orifices. All in a line. The first orifice is the only one exposed to engine vacuum at idle. This should be the culprit. It is the farthest from the fuel source.
If the rest of the orifices were not open/clean, the bike would not run well at any low throttle openings.
If I had this, I would probably pull the close off valve assemblies and the pilot gas jets. I have the nozzles for the blow gun necessary to backwards blow out the pilot circuit. About 25# air regulated.
My best guess. HTH
wmsonta is offline
post #6 of 22 (permalink) Old 12-31-2013, 04:03 PM
I would expect that.
wmsonta is offline
post #7 of 22 (permalink) Old 12-31-2013, 04:13 PM Thread Starter
My best guess. HTH
sounds logical but i did acid dip everything metal for over 24 hours and blew everything out
could a slightly bent needle cause the same symptoms cause i dont remember checking them to see if they were bent i just cleaned them and stuck them back in
post #8 of 22 (permalink) Old 12-31-2013, 04:22 PM
First, the pilot circuit gets slightly smaller the farther away from the gas jet. They really should be blown out backwards. The cut off valves should be removed when using air/solvents on the pilot circuit. The cut off valve vacuum port is in the roof of the throttle bore straight above the pilot idle port on the floor. Any solvent/vapor available to this port will go directly to the cut off diaphragm.
The needle will have nothing to do with idle. Even if the slide is stuck raised.
Did you remove the air jets to soak the carbs? The pilot and main air jets would be hard to distinguish at a glance.
wmsonta is offline
post #9 of 22 (permalink) Old 12-31-2013, 04:26 PM
Dirty petcock?
Will it run on a bottle? ,, bypass the tank
post #10 of 22 (permalink) Old 12-31-2013, 04:38 PM
Magnusvela's Avatar
Make sure your diaphram needles are in the right carb. Different size needles front and back!
Magnusvela is offline
